How do I.......
Old Jun 29, 2012 | 06:09 PM
Snidley's Avatar
Snidley
Default How do I.......
Remove the coils and valve covers and re-hook the coil packs so I can check out and work on the rockers?
I know how to take it apart, just don't know the best way to get the electric to the coils and keep them away from the rockers.
Steve
Old Jun 29, 2012 | 06:47 PM
bumble-z's Avatar
bumble-z
Why do you need electric to the coils when working on the rockers?
Old Jun 29, 2012 | 08:23 PM
Lothar34's Avatar
Lothar34
Do you mean you want to run the engine with the valve covers off?
Old Jun 29, 2012 | 08:45 PM
Snidley's Avatar
Snidley
Exactly. Getting some noise from that area, but can't narrow it down with the valve covers on.
Old Jun 29, 2012 | 09:09 PM
Lothar34's Avatar
Lothar34
You're going to squirt oil all over the place. Make sure it doesn't get on your exhaust manifolds.
I don't know what to tell you about the coils.
Old Jun 29, 2012 | 10:09 PM
Paul 75 L82's Avatar
Paul 75 L82
It's a bad idea. Get an automotive stethoscope and listen to each rocker with the valve covers on. You can hear everything with that. Then remove the covers and inspect.
Old Jun 29, 2012 | 10:15 PM
m6 c5's Avatar
m6 c5
Yea this is the best idea unless you want to cut up a set of valve covers so you can run it without spraying oil all over the place...
Old Jun 30, 2012 | 02:17 AM
cptinjak's Avatar
cptinjak
why not turn the motor over by hand?
Jack
Old Jun 30, 2012 | 06:08 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Jack
If he could turn the engine over by hand at 1000 RPM to duplicate the noise... I would say he is wasting his skills posting on this forum.
Old Jul 2, 2012 | 06:53 PM
Snidley's Avatar
Snidley
A few "Don't do its" but not one how to re-connect the coil packs. I used to remove the valve cover to adjust valves on the 1970 Vette I had, so I figure this can't be too different, except for the coils being in the way.
Any one?
Old Jul 2, 2012 | 06:57 PM
lucky131969's Avatar
lucky131969
Any one?
Completely different. The only way to do it, would be to use long plug wires, or make an extension for the coil harness. Sure, you could remove the valve cover, and plug up the coils , but then they are in the way for inspection anyway( plus you have to find a way to suspend them)....while the motor is running. So.....have you tried a stethoscope, to isolate the noise?
Old Jul 2, 2012 | 07:07 PM
Snidley's Avatar
Snidley
I realize that I have to move the coil packs out of the way. I was hopping there was an extension for the electric to the packs that was available.
I have listened with the stethoscope, and can narrow it down to one or two rockers. Still need access to the rockers while running to do better, unless, of course, its obvious that the bearings are falling out of one of them.
Listening to them is good. To really figure it out, I think I need to see them in action.
Steve
Old Jul 2, 2012 | 07:09 PM
lucky131969
Steve
Little confused here Steve. If you have it isolated, what is keeping you from pulling the valve cover, and investigating?
Old Jul 2, 2012 | 07:17 PM
Snidley's Avatar
Snidley
Just want to be able to run it when I do pull the cover. Never liked doing thing twice if I can be prepared for most cases.
Beginning to look like just pulling it for a visual non-running inspection will be my first step.
Steve
Old Jul 2, 2012 | 07:24 PM
bumble-z's Avatar
bumble-z
Now your talking.
To How do I.......
