i have a 2000 coupe that i was thinking about changing out the tunnel plate with an elite engineering one. i also have a magnaflow cat back system with the x pipe and i want to change out the axle back part with a titanium z06 one.
my question is, how hard is it to get the center section of the exhaust system off to get at the tunnel plate? it looks like i need to unbolt at the exhaust manifolds and i am not sure how much room there is. i would be doing this with ramps and jack stands. the ramps are about 10 or 12 inches high (i made them from plans i got here on the forum).
another question, how high do i need to get the rear end of the car to change out the mufflers without any cutting? i saw on the forum that it needed to be 30 inches, but i am not sure where that is measured.
for any of you guys that have done it before, is it worth it or should i just take it to a shop and have it done?
the only other thing i have done under the car is to change out the transmission fluid and install the cags eliminator. that wasn't too hard.
thanks, elite says you can re-use the stock bolts. now i just have to decide if i feel safe with the car up that high. i know lots of guys have done it but i don't know.
to make it safer, I have seen a few guys back up to a loading dock and service the exhaust there, plenty of room but better have a buddy you can trust to spot you positioning the car or you will have a great story for us! Otherwise when i needed to lift a vehicle that high I would use pieces of 6x6 as cribbing then a jackstand up top, unextended. 4x4 truck jackstands (6 ton) are a lot more stable with a lot more lift than the little 2 ton models.
Be careful with the manifold bolts. They break pretty easily. Best is to try them carefully and if they're giving trouble use a small torch flame to apply a little heat. Otherwise, you'll be replacing the studs.
I suggest taking it to a shop to have the t/plate & Ti system installed.
We want you safe & to be around awhile, here on the forum.
to make it safer, I have seen a few guys back up to a loading dock and service the exhaust there, plenty of room but better have a buddy you can trust to spot you positioning the car .......
I had not thought of that, but it sounds like a good idea that would be a cheap and easy way to do it.
