Brakes, Running diff brands/compounds
Old Jul 2, 2012 | 12:52 PM
maxG's Avatar
maxG
Default Brakes, Running diff brands/compounds
So I have a track day coming up. I was told a month ago that my fronts are at 50% and after a track day they will def need to be replaced. Well its been a month, and my track day isnt until the end of july and I am getting nervous that i may run out of pad at the track day. So I am trying to decide, do I buy another set of front oem pads for the track day, or do I buy a set of hawk pads for the fronts and run my OEM rear pads which are at 80%? Will that be less than optimal for the track running two diff pads front to rear?
I was thinking the HPS pads and I plan to have these for street driving while I will get a whole new set of pads, rotors that will be dedicated to the track for the future after this first track day.
any feedback will be appreciated since i need to buy these soonish.
Old Jul 2, 2012 | 12:54 PM
maxG's Avatar
maxG
PS I am low on cash getting ready for the track day, so thats why I am not buying all new brakes pads now and why I dont want to buy new OEM fronts as they are a bit more expensive than the hawks. I have had my car tech'd and the only thing he pointed out was the 50% front pads.
Old Jul 2, 2012 | 02:41 PM
Last C5's Avatar
Last C5
Go ahead and stick a set of Hawks in the front. The fronts are doing 90% of the braking and your OEMs aren't going survive a whole session without fading if you're putting down any speed at all.
Lots of people run different compounds front and back. A good example is running Carbotech 10s in front and 8s in back, which a lot of cars do.
Old Jul 2, 2012 | 03:44 PM
maxG's Avatar
maxG
I had heard about the different carbotech compounds but I was worried about running entirely different brand pads. I will likely do as you suggest. Not to discredit Last C5's advice but does anyone else with experience as well have any input? also how do the HPS pads compare to the stock pads, will they perform less than the OEM's?
thanks!
Old Jul 2, 2012 | 05:33 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
thanks!
Opinions on brake pads are like a-holes, everyone has one and most of them stink. My Z had HPS on it when I bought it and I did not like them. In my opinion the HPS pads are not noticeably better that a stock Z06 pad; they will start to fade after a few high speed stops. For a high speed event I'd recommend Hawk HP+ pads as a minimum. They are noisy when cold and dirty but they stop well and do not require much warming up. BTW what are you calling a track day and what speeds will you be running?
Old Jul 2, 2012 | 05:44 PM
maxG's Avatar
maxG
its an HPDE day and I will be in the intermediate run group. I plan to get a second set of track oriented pads (hp+) and rotors but dont have the funds for all of that for now. I was told the oem pads stop fine for now but mine are around 50% so thats why im looking for something that will get me through a track day. so I narrowed it down to OEM or HPS's. I certainly dont want something that is worse than stock.
Old Jul 2, 2012 | 06:01 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Don't waste you money on high dollar aftermarket rotors, the OEM rotors or a high quality OEM replacement like a Centric or Napa Premium will work fine. High speed braking along with aggressive pads will wear out the rotors quickly; they will become disposable items if you do this often enough.
The HPS pads or the OEM Z06 pads will work however just be cognizant of when they start to fade. You may have to run some cool down laps during the event to keep them from exceeding their maximum recommended operating temperature and fading away completely. I would not participate in a HPDE with pads that are already worn to the level you describe without planning on performing a mid-event brake inspection and having a spare set of pads with me. Good luck.
Old Jul 2, 2012 | 06:29 PM
Z06TWT's Avatar
Z06TWT
I have these pad on my C5Z and was told by Reese *** (MTI)that the conventional logic of softer rear pads (8 vs 10) is flawed because the rear caliper and pad is much smaller these need at least the same pad as the fronts, not less...so run 10s all around
Old Jul 3, 2012 | 02:37 AM
Last C5's Avatar
Last C5
I run 10s all around also. But, in the past when I have run 8s in the rear there was no noticable difference in the way the car handled in the shut down zones or while trail braking.
Old Jul 3, 2012 | 04:18 AM
LagunaPete's Avatar
LagunaPete
I have had very good experience with Porterfield Pads. I'm not exactly sure of the total makeup but I am pretty sure it is mostly carbon kevlar based. They do not fade at very high speeds. Instead of fading they become sacrificial. I have taken various vehicles on them for an entire day. Some were heavy cars like SL600 and end of day wear has never been worse than 30% remaining, and some stops were real pad ripping ones. They always hold intact with a hell of a grip. They are worth trying. They make a street version as well. They are on Placentia in Costa Mesa CA.
I don't mean to plug them its just that they are small and might be hard to find.
To Brakes, Running diff brands/compounds
