CD/Aux will not activate CD
Old Jul 4, 2012 | 01:54 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Default CD/Aux will not activate CD
I have a stock CD player in my 98. A couple of months back, I installed the i-Simple to run my i-Pod. It has worked fine. Yesterday, the CD player would not change tunes on the iPod, then gave the ERR message. Now all I can get is AM/FM, and the CD/AUX will not activate. I do not have the rear changer, just the single CD player. I've disconnected the battery, I pulled the unit and checked the connections, and I even removed the i-Simple and put everything back to stock, but no success. I did not see a sepatate fuse for the CD, just a radio fuse. Any suggestions would be appreciated. Thanks Zuti
PS - I did a search, but found nothing current regarding the standard CD, only the rear changer unit.
