DIY Diff Replacement
Old Jul 9, 2012 | 08:49 PM
Rob's 73's Avatar
Rob's 73
Default DIY Diff Replacement
Does anybody have some detailed instructions? Links to Mike Mercury's don't seem to work for me. http://mikemercury.home.att.net/342.htm
Thanks in advance.
Rob
Old Jul 9, 2012 | 08:52 PM
lucky131969's Avatar
lucky131969
Thanks in advance.
Rob
I did a google search for "c5 differential swap"....and came up with this...
http://www.tim-yvonne.com/mikemercury/342.htm
Old Jul 10, 2012 | 12:20 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Rob, Patches posted this 5 years ago. It's an auto but it has a lot of pics!
http://forums.corvetteforum.com/c5-g...mega-pics.html
__________________
Old Jul 10, 2012 | 10:28 AM
tierod's Avatar
tierod
Cruising
dont forget to tighten the carrier or sub frame mounting bolts with a ratchet only, along with the trans/diff mount. An impact will break the bolts off the mount and break the weld for the nut on the frame! learned from experience, Later reading through the assembly manual I read where it says use hand tools only on these bolts. Good luck !
Old Jul 10, 2012 | 02:06 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If you have an A4 best and easiest way is to remove BOTH the trans and diff in one piece at the same time---otherwise it's difficult to get just the diff removed as the rear trans shaft that goes into the diff is so long that you have to lower the whole engine/trans assy. and even remove the TQ tube cover to let it drop far enough-
Old Jul 10, 2012 | 04:17 PM
Mike Mercury's Avatar
Mike Mercury
Thanks in advance.
Rob
new domain:
To DIY Diff Replacement
