113 vs. 114 lsa cams
Old May 27, 2002 | 12:54 PM
Mitch C's Avatar
Mitch C
Default 113 vs. 114 lsa cams
What if any are the differences between the two? Will one or the other give you a better idle or more power with acam with the same durantion and lift?
98 A4
Powerloaded
Donaldson Blackwing
172 t.stat
Pro Torque 2400
3.42 Gears
Old May 27, 2002 | 02:34 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
[Modified by 2000^C5, 12:35 PM 5/27/2002]
Old May 27, 2002 | 02:35 PM
2000^C5's Avatar
2000^C5
Default Re: 113 vs. 114 lsa cams (Mitch C)
114 will give a little better idle while the power band of the 113 will come down 100 rmps or so lower.
Old May 28, 2002 | 12:01 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: 113 vs. 114 lsa cams (2000^C5)
That sounds about right, especially for the A4!
Old May 28, 2002 | 01:48 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: 113 vs. 114 lsa cams (Buckmaster)
lets just put it this way, I am building 430 RWHP at 6200 RPM's instead of 6800 RPM's. Difference between the 112 and 114. More mid range hp and tq.
To 113 vs. 114 lsa cams
