Disable Outside Temp Default Display
Old Jul 12, 2012 | 02:40 PM
a911sc's Avatar
a911sc
4th Gear
Default Disable Outside Temp Default Display
I've searched with no luck. Is there a way to disable the outside temp default display and just have it default to the interior temp. setting?
I would rather see the inside temp. setting as the default and be able to toggle to the outside temp. only when desired. IMO the outside temp. is secondary and I'm not sure why they set it up to default this way?
TIA
Old Jul 12, 2012 | 03:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its a setting programmed inside the HVAC Module. Unless you have a way to flash and reprogram chips and microprocessors, I dont think you can change it
Old Jul 12, 2012 | 10:28 PM
Never heard of anyone doing this. You could be the first. Let us know if you find a way.
Old Jul 12, 2012 | 11:49 PM
jrose7004's Avatar
jrose7004
I can't imagine why you'd want it that way but good luck figuring it out.
Old Jul 13, 2012 | 03:55 AM
65GGvert's Avatar
65GGvert
You could move the outside temp sensor inside the car. Use a long extension set of wires. The a/c won't work correctly anymore. I can't imagine why you would go through that. Buy a little stick on digital thermometer to carry with you if you need to know the current inside temp. If I'm hot, I just roll the a/c temp down till I'm not anymore and vice versa. Setting it to 73 is usually pretty comfortable unless the top is down.
To Disable Outside Temp Default Display
