Turn Signal Problem (again)
Old Jul 12, 2012 | 03:07 PM
Vintagevetter's Avatar
Vintagevetter
Default Turn Signal Problem (again)
I noticed on my recently acquired 2001 Z06 that the turn signals stop working. When ever I move the turn signal lever in either direction, I get a loud buzz from behind the dash...but the signals don't work.
I did a search on here for the problem and found quite a few threads
concerning fixes. I would like to narrow this down to what most people
think the best solution is to this problem
Jeff
Old Jul 12, 2012 | 03:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CYCLE the emergency flasher button on and off 25-30 times and see if that changes the problem. If it does, highly recommend the flasher by-pass mod.
The turn signal/lheadight multifunction switch can also go bad and cause your issue.
Old Jul 12, 2012 | 05:39 PM
Vintagevetter
Thanks Bill....I will give your suggestion a try
Jeff
Old Jul 12, 2012 | 05:44 PM
I dream of vettes's Avatar
I dream of vettes
My signals stop working every now and then but I have never heard the buzz you describe. When this happens, I normally push the hazard switch in a few times and it fixes the problem. I've been told the hazard switch might be going bad and will soon have to be replaced.
To Turn Signal Problem (again)
