Low idle after batt replacement
When I come to a stop, the RPMs drop to 400 and eng shutters a bit. After abt 2 sec, the RPMs climb back to 600 and idles very nice. It happens every time I stop at a light.
The IAC compensates for the A/C being on or off just fine.
I thought the computer might need to re-learn something, but it has been a couple of months now and it still does it.
It didn't happen before batt replacement.
Other than this issue, the car runs perfectly.
Any ideas?
C5 Idle Relearn Procedure
Purpose
This page basically shows you step by step how to do an Idle Relearn. You would want to do this if you have done any intake modifications. If you do not do this, you may have hesitation or other issues.
Tools Required
None.
Do the Job
Follow these procedures EXACTLY or you will have to start from scratch.
Insert key into ignition and turn to the "On" position but, DO NOT START THE ENGINE.
Pop open the engine fuse block box cover and remove the two 10amp fuses from position numbers 16 & 23.
Your DIC will now display "check" messages for ABS, etc...
Turn ignition to the "Off" position.
Re-insert both 10amp fuses for positions 16 & 23.
Start your engine
Allow engine coolant temperature to reach a minimum of 176 degrees F and run at this minimum temperature for at least 5 minutes.
Shut down engine
Let rest for a minimum of 30 seconds.
Restart engine - check for DIC error codes (there should be none).
Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and air temperature at the intake.
I'll give the idle re-learn a try tomorrow.
After a bit more reading, I discovered I have no IAC. Oops!
Guess I been under the hood of my 3rd gen Camaro too long...
BC
