Car lurches and engine dies
Old Jul 23, 2012 | 10:44 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default Car lurches and engine dies
ENGINE STALLING- July 22, 2012
The (2001 manual trans) car ran perfect earlier in the day. A few hours later, and after a rain storm, the ignition answered with a couple of clicks, which is usually the dreaded sound one hears when a battery gasps it's last breath. The hood was down, and nothing critical could have gotten wet. However, the electrical system was dead to all functions, ie. interior lights, radio, door locks, trunk lid and everything else. A fully charged portable battery pack had no effect either. The system remained dead.
Today I decided to give it one more try, when I was greeted by a couple more clicks, before the engine roared to life. I let the engine idle for a while, and all seemed well.
However, when I tried to drive, the car lurched foreword a few feet, before the engine died. I was able to park the car again with repeated lurching, and repeated restarts. (Water in the gas comes to mind immediately, but that won't effect the electrical system.)
If anyone had a similar problem, or can offer a possible answer to what will cure the problem, it will be much appreciated, before I surrender my wallet to the local GM Dealer. (Who otherwise be nice people, for all I know.)
Regards, GRT
Old Jul 23, 2012 | 11:24 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I'd check to be sure the battery cables are clean and making good contact. If you suspect the battery and have another you can use to try, I'd do that. With the crazy things I've seen upon a batteries death, it would not surprise me if they could die and come back to life, just enough to cause you additional headaches. I've had plates in them weld together, but never seen one do that and then work again, even for a moment. Considering the construction of them though, it would not surprise me if they could short out intermittently when a piece gets loose in there.
Old Jul 24, 2012 | 12:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What is the SECURITY LIGHT on the dash doing when the key is ON and when the key is ON and the engine is running??????????
Sounds like a security issue that enables the 2 mph fuel cutoff.
BC
Old Jul 24, 2012 | 12:24 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
I suggest that you pull and post the codes:
OR
http://www.c5forum.com/ayc/dtcdic.php
WOW,,, ZIP hit the ball out of the park on that one!!!
Well Done Justin!!!!!!!!:thumb s:
Bill
To Car lurches and engine dies
