Battery Disconnect Question
Old May 28, 2002 | 05:18 PM
kenc5's Avatar
kenc5
Default Battery Disconnect Question
I will be putting my car into the Charlestowne mall in St. Charles tomorrow to hype the Bloomington Gold. The mall requires that we disconnect the battery. Will I have a problem after disconnecting the battery other than radio stations and clock? Sorry if this is a stupid question. Thanks.
Ken
Old May 28, 2002 | 05:52 PM
My401K's Avatar
My401K
Default Re: Battery Disconnect Question (kenc5)
I think if you connect one of the battery savers in the cigeratte lighter, it will save the radio settings. Uses a 9 volt battery to hold settings.
Old May 28, 2002 | 08:05 PM
carpe dm's Avatar
carpe dm
Its a good question, and the answer is that you should not have any problems at all. :)
Old May 28, 2002 | 08:54 PM
Patches's Avatar
Patches
I left my battery disconnected overnight once and had zero problems. :)
Old May 28, 2002 | 09:02 PM
dmkc's Avatar
dmkc
Dont forget your radio code before you disconnect the battery
Old May 28, 2002 | 09:44 PM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
I have disconnected my battery many times for days at a time while upgrading the stereo and alarm. Somehow it still remembers my settings. :confused: No problems at all. :smash:
Old May 29, 2002 | 04:27 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
You will only have to reprogram your key FOBs. Check the owners manual. It's simple.
Old May 29, 2002 | 07:52 AM
C5XTASY's Avatar
C5XTASY
Default Re: Battery Disconnect Question (JTE)
This is true. I remove the car's battery completely when mine goes into storage each winter (Minnesota - :sad: ) and the only settings lost are with the fobs. You may have to perform an idle relearn, though, or just drive the car for 50 miles, or so, if the PCM reverts back to factory settings from adaptive settings. This certainly is not a big deal either as the car will run fine and perform the relearn all by itself. You will not even know it's happening, except the car may run a little smoother and quicker.
Ed
Old May 29, 2002 | 11:14 AM
kenc5's Avatar
kenc5
Thanks a bunch, guys. I appreciate the input.
Ken :cheers:
To Battery Disconnect Question
