Hard Ride
Old Jul 27, 2012 | 03:24 PM
taximan's Avatar
taximan
3rd Gear
Default Hard Ride
I have a 2004 convertible, the car is stock. The ride has gotten hard over bumps, There is a magnetic ride control switch, there is no difference when I switch the **** from tour to sport, has anyone had this trouble, car has 83,000 miles, do I need new shocks or is there other problems.
Old Jul 27, 2012 | 05:15 PM
andrec10's Avatar
andrec10
How old are the tires? Could be the shocks combined with age and miles too.
Old Jul 27, 2012 | 07:38 PM
Cybermind's Avatar
Cybermind
Has it become hard over time or was it always like that? The reason I ask is because there is a slight chance that the shipping stoppers were never removed. But, at 83k miles I would be really surprised. So yes, your shocks may be worn to such a point that you're hitting the bumpstops. You need to have it checked out, or get under there and check it yourself.
Old Jul 28, 2012 | 03:14 PM
taximan's Avatar
taximan
3rd Gear
Default Taximan
It seamed to start @ the end of last year, it used to ride smooth
Old Jul 28, 2012 | 03:16 PM
taximan's Avatar
taximan
3rd Gear
The tires are 4 years in the front, 3 years in the back
Old Jul 28, 2012 | 03:32 PM
Bluefire's Avatar
Bluefire
I have an '03 Coupe w/MSR. About a year ago I noticed that the "Tour" setting got mushy and floaty, while "Sport" got very harsh. IMHO this all points to reduced or no damping. I replaced mine with Pfadt c/o and it handles like a dream again.
Old Jul 30, 2012 | 11:27 AM
Pfadt Racing's Avatar
Pfadt Racing
Sounds like you're having issues with the factory shocks. After seeing a ton of these threads it seems that 80,000 miles is about the average for the magnetic ride shocks to need attention. I would take a look under the car and check the 4 shocks for leaks or the the car in for a diagnostic if you really want to keep the Mag Ride setup. Just keep in mind that if there something is wrong with the shocks themselves they can be extremely expensive to replace.
We have both coilover and fixed shock packages which will get you back on the road with MUCH improved handling should you decide to upgrade your suspension. Either our Johnny O'Connell package or our FeatherLight Singles would offer great handling, excellent ride quality, and likely be less expensive than replacing all 4 Mag Ride shocks.
Old Jul 30, 2012 | 09:01 PM
corv1998's Avatar
corv1998
I have gone through my 98 suspension wise . After replacing shocks with bilsteens and new sway bars the car still was a little rough over the buffalo roads. I ordered a new zo6 front spring and wow it made all the difference i was looking for .You never realize how bad your parts are untill the new ones show up.
Old Jul 31, 2012 | 04:14 PM
jlbsam's Avatar
jlbsam
my 99 rode very rough, but i replaced the run flats with all season non r/f's Kumho's and replaced the expensive worn out shocks with z06 shocks. made a huge difference.
To Hard Ride
