Run hot when ac on
Old Jul 28, 2012 | 04:27 PM
Ready Z06's Avatar
Ready Z06
Cruising
Default Run hot when ac on
I have a 02 Z06 If I'm sitting at a light with my ac on the car will start to run hot and ac will cut off at around 234 temp but when I start driving it goes down. I checked my fans and there working can anyone help me with this problem
Old Jul 28, 2012 | 04:32 PM
Corvette_Ed's Avatar
Corvette_Ed
When was the last time you cleaned out the area between the radiator and condensor?
Old Jul 28, 2012 | 04:48 PM
Ready Z06's Avatar
Ready Z06
Cruising
I did it last week and there was not really any debris so I'm trying to see if it could be something else
Old Jul 28, 2012 | 05:17 PM
Ready Z06's Avatar
Ready Z06
Cruising
If stop it does climb but when the AC cuts its self off it starts to go down And the AC is real cold the fluid is full
Old Jul 28, 2012 | 05:22 PM
Ready Z06's Avatar
Ready Z06
Cruising
Im not sure what you mean is the hose sucked closed
Old Jul 28, 2012 | 08:08 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
try to bleed the system. open the rad cap. and run// sounds like there is some air in the system
Old Jul 29, 2012 | 10:51 PM
Ready Z06's Avatar
Ready Z06
Cruising
Thanks everybody for your help I power washed the radiator and ac condenser and took my time the temp went back to normal. So thanks guys for everything
Old Jul 30, 2012 | 12:47 AM
CBZZZC5's Avatar
CBZZZC5
My 97 coupe does the same thing. I was stuck in bumper to bumper in So Lake Tahoe for over an hour and the temp sat at 235/240 with the AC on full. As soon as we got into the open it cooled right back down to 192. No debris ion the rad. but I will give it a good wash and check out 8vetts7 advice.
To Run hot when ac on
