C5 Torque Specs
Old Jul 31, 2012 | 12:31 PM
thedudeman's Avatar
thedudeman
Default C5 Torque Specs
Hey guys,
I'm looking for torque specifications for the windshield wipers on a 1999 corvette. Also, is there a source on here or another site you know of that has torque specs for the whole car? Thanks!
Old Jul 31, 2012 | 01:18 PM
lucky131969's Avatar
lucky131969
Originally Posted by thedudeman
Hey guys,
If you are going to be working on your own car, having the factory service manual is invaluable. While there are a few places to obtain torque specs online, they are only as accurate, as the people typing the info.....get the bible, and work with confidence.
Washer Solvent Container Nuts - 8 N·m; 71 lb in
Wiper Arm Nut -25 N·m; 18 lb ft
Wiper Motor Crank Arm Screw - 15 N·m; 11 lb ft
Wiper Motor Module Bolts - 10 N·m; 89 lb in
Wiper Motor Module Upper Bolt - 10 N·m; 89 lb in
Wiper Motor Screws - 10 N·m; 89 lb in
Wiper Transmission Bolts - 10 N·m; 89 lb in
Old Jul 31, 2012 | 01:21 PM
thedudeman's Avatar
thedudeman
Thanks for the fast response. I'm looking for a good set of manuals now, thanks!
Old Jul 31, 2012 | 02:32 PM
PUMP03's Avatar
PUMP03
Oldtimer
The attached pdf file with 99% of torque values came direct from the ESI (not manually copied). I created this so I could have a quick reference on my Ipod. Has bookmarks for major systems and is searchable. Works great.
Old Jul 31, 2012 | 02:37 PM
Scooter70's Avatar
Scooter70
David Farmer's C5 torque spec sheet: http://dl.dropbox.com/u/1634366/C5torque.pdf
Old Aug 1, 2012 | 08:37 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I was not looking for these specs, but since you guys made the effort I dowloaded then, for quick ref. Thanks ,Ron
To C5 Torque Specs
