reading codes on DIC for a C6
Old Jul 31, 2012 | 04:49 PM
NealB's Avatar
NealB
Default reading codes on DIC for a C6
Anyone know if the procedure to read OBD codes using the DIC is the same for a C6 as it is for a C5?
Or where to find the C6 process so I can compare to C5 process?
I looked on the C6 Tech DIY thread and also searched in the Scan and Tune section and didn't see the C6 process.
Old Jul 31, 2012 | 05:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Nah, Chevrolet took that away in the C-6 and probably in whomever's wisdom or lack thereof, decided we'd have to take the C-6's to their dealers instead. We can indeed get to the PCM/ECU codes with a CAN Enabled code reader but not the other codes.
Old Jul 31, 2012 | 06:57 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Sounds like it's time for someone to track down the protocol and DIY a reader. Of course, it would be easier if someone found a cheat that makes the car spit out the info.
Old Jul 31, 2012 | 11:50 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I looked into that a couple of weeks ago.
It makes you appreciate the C5's! A nice feature to have.
Old Aug 1, 2012 | 09:45 AM
dgrant3830's Avatar
dgrant3830
Of all the code readers out there, seems there would be more than Vetronix/Bosche that would produce a reader capable of getting to the other modules with having to shell out $3500 and more for a Tech2
Old Aug 1, 2012 | 03:45 PM
QCVette's Avatar
QCVette
Do any of the tuners have access? Like HP Tuners or EFI Live?
To reading codes on DIC for a C6
