Head up display
Old Aug 1, 2012 | 05:41 PM
mrgil's Avatar
mrgil
Burnout
Default Head up display
I need some help here, does anyone have an answer to my question?
I'm having an issue with Heads up display in that it is all lit up, with all info & showing 188 mph and is intermittent. if I bang an the dash it works OK for a while then freezes up again or goes blank.
Does anyone know what causes this?
Loose connector, bad ground?
Where do I start looking?
mrgil
Old Aug 1, 2012 | 06:11 PM
f6john's Avatar
f6john
That's a new one on me, interested in the fix too.
Old Aug 1, 2012 | 10:07 PM
jrose7004's Avatar
jrose7004
I've never heard of that one either. I've seen mine all light up if the sun's reflextion is just right. Other than that, I've never heard of that happening.
Old Aug 1, 2012 | 10:10 PM
Banditz's Avatar
Banditz
IF she lights up when you "bang" on the dash then you have answered your own question brother. A loose connector. Bad joint, or basically bad connection. Anything electrical internally would NOT be affected by a bump...
Old Aug 3, 2012 | 07:57 PM
mrgil's Avatar
mrgil
Burnout
Default Hud
mrgil
OK... Stockman and I pulled the IPC out this AM
Checked all the connections, reinstalled and it still doesn't work right
Anyone with any further suggestions.
mrgil
Old Aug 5, 2012 | 01:01 PM
mrgil's Avatar
mrgil
Burnout
Default ttt
ttt
Old Aug 5, 2012 | 04:18 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Just out of curiosity, have you tried it with your Window Valet removed from the OBDII diagnostic connector?
Old Aug 6, 2012 | 07:27 PM
mrgil's Avatar
mrgil
Burnout
Just finished doing that, it was working fine again before and after i pulled the window valet.
I'm going to go drive it and if it quits again I'll pull it and see what happens.
mrgil
Old Aug 6, 2012 | 07:32 PM
Jumper11's Avatar
Jumper11
Whats a window valet?
Old Aug 6, 2012 | 07:57 PM
mrgil's Avatar
mrgil
Burnout
Go to the top of this post where the blank box is...its called a search box
and type in "window valet"
you will get a whole bunch of posts, scroll down til you see one from southern car parts and click on it.
mrgil
Old Aug 12, 2012 | 11:28 AM
mrgil's Avatar
mrgil
Burnout
mrgil
update Replaced battery still doesn't work driving car then it flickered and started working then quit again
what a PIA works ok for now..... wait a minute, it stopped again. everything lit up.
Banging on the dash does nothing. Anyone any ideas???
Old Aug 12, 2012 | 06:50 PM
oh1vette's Avatar
oh1vette
Hit the dash harder(?)
Old Aug 17, 2012 | 12:33 PM
mrgil's Avatar
mrgil
Burnout
mrgil
This is driving me nuts, sometime it works sometime it don't.
Banging on the dash doesn't help.
Sometimes it goes out completely sometimes it works fine and sometimes it flickers off and on.
Is it a connection or one of the components, I have searched everywhere trying to find out how a HUD works, where does it get the signal from?
I know it is projected onto a lens or mirror to lite up the windshield.
can anyone explain this? It may shed some lite on where I can start to look for an issue. I do not believe its a grounding issue.
mrgil
Old Aug 17, 2012 | 01:26 PM
oh1vette's Avatar
oh1vette
Look up Steve Dolton on here - he does alot of HUD installs I understand...he may have a clue...
Old Aug 17, 2012 | 01:35 PM
LoneStarFRC's Avatar
LoneStarFRC
mrgil
It gets it's data signal from the IPC.
If you have all the other functions working, i.e. up/down, mode change, bright/dim, etc then maybe it's the IPC itself. Of course it could be the actual vacuum-flourescent display screen itself in the HUD projector.
If I were forced to guess, I would suspect projector first.
HTH
Old Aug 17, 2012 | 01:37 PM
DeeGee's Avatar
DeeGee
This one's a new one on me too. From all you describe it has to be a loose connector or a bad component. Haven't looked but is there a connector on the HUD projector?
Old Aug 18, 2012 | 12:01 AM
mrgil's Avatar
mrgil
Burnout
HTH
As far as the functions go, up down works, brightness control works,
paging does not work,all display items are lit up all the time or not at all.
gil
To Head up display
Old Aug 24, 2012 | 09:10 PM
Mitcheal's Avatar
Mitcheal
4th Gear
Default Heads up Bezel
Hey yall anyone got an answer of how to install the black plastic HUD Bezel Display? 2004 Corvette
Old Aug 25, 2012 | 05:21 PM
mrgil's Avatar
mrgil
Burnout
gil
More new info;
When the engine is cold at startup it flashes and shows everything, then switches to the correct display, ie rpm,speed etc....Once the engine warms up, it flickers then stays all lit up.
It's got me stumped.
mrgil
Old Sep 28, 2012 | 08:39 PM
mrgil's Avatar
mrgil
Burnout
Default Hud
Update, replaced the HUD switch still doesn't work. I'm beginning to suspect the IPC I also read some place on this forum that the serial data connector in the doors could also cause some issues, going to check those tomorrow. I'll keep you posted
mrgil
aw what the hell maybe I'll just buy a new one 2013? or 2014?
