Transmission to rear diff leak
Old Aug 2, 2012 | 04:52 PM
skeeters65's Avatar
skeeters65
Default Transmission to rear diff leak
My car seems to have started to leak where the trans bolts to the diff?
Not the Axle shafts like normal.
Is this common?
How hard to fix?
Clutch is getting swapped soon. Will do it at the same time.
Is it just a gasket or o-ring in there?
Old Aug 2, 2012 | 08:36 PM
skeeters65's Avatar
skeeters65
Red.
I am sure its trans fluid.
Just wondering if its as easy as unbolt the 2 swap the gasket/seal and out back together?
Old Aug 3, 2012 | 12:07 PM
skeeters65's Avatar
skeeters65
Originally Posted by bumble-z
Is it leaking here? See link below
http://forums.corvetteforum.com/c5-t...-pictures.html
Or between the differential & rear of transmission?
Between the rear of trans and the diff. Right in front of the rear leaf spring..
Old Aug 11, 2012 | 02:34 PM
skeeters65's Avatar
skeeters65
Anyone?
Old Aug 11, 2012 | 04:13 PM
cptinjak's Avatar
cptinjak
If it's not leaking @ the tailshaft/& main tranny (As in prevous picture) then your going to need the large O Ring.
GM. Part# 12369456
See Picture below, to see large O Ring
http://forums.corvetteforum.com/1573560188-post16.html
NO. if it is leaking ATF from the diff/trans mating surface, then the output shaft seal is leaking from the case into the diff, and THEN leaking out the o-ring.
The only other possibility is someone filled the diff with ATF, and let's pray that didn't happen.
Jack
Old Aug 11, 2012 | 04:54 PM
zeevette's Avatar
zeevette
The interface between trans and diff is a very foolproof O-ring fit, so unless the two have been seperated, it's very unlikely that's the source of the leak. BTW, if you have to replace the seal, it's no biggie, if doing the clutch; but otherwise, it's alot of work (or $$$) to replace.
Old Aug 11, 2012 | 07:36 PM
skeeters65's Avatar
skeeters65
Damn no you got me second guessing myself. I will look again and see where it is coming from.
Old Aug 13, 2012 | 11:58 AM
skeeters65's Avatar
skeeters65
Hey guys. Last night I climbed under there and cleaned it up good. This morning I looked under there and it was definatly red. I took a few pics. I can text them or e-mail them if anyone can help me out.
Old Aug 13, 2012 | 12:48 PM
bracketshark's Avatar
bracketshark
Default leak
I have my transmission apart right now, Mine was leaking where the seal housing bolts to the transmission. I think it would be difficult to replace the seals without taking this part off the transmission because there are 2 seals in there. One would keep Gear oil or contaminants from entering the transmission and the other to keep transmission fluid from getting out of the gear box. This is not a difficult repair with the transmission/differential out. I'm not even going to replace the seals in mine, they look that good. Evidently GM's gasket maker/sealer has a given life span and its up for the most part in our cars.
Old Aug 13, 2012 | 09:02 PM
FourG63 97GST's Avatar
FourG63 97GST
thats really interesting, but anything is possible I guess, i'm curious what the differential fluid looks like. because they should be mixing, from the output shaft leaking trans fluid into the diff, and for the leak to still come out red, it would have to be alot of trans fluid in there, what am I missing?
Old Aug 13, 2012 | 09:36 PM
curtbriggs's Avatar
curtbriggs
A constant fluid level in the differential. If transmission fluid was leaking out and also transferring to the differential, that fluid level would go up.
FWIW, my 99 is leaking and friends 2001 and 2004 both leak transmission fluid from the 6M transmissions. I have a gut feeling that the leak slows or stops when it's up to operating temperature.
Cheers, Curt
To Transmission to rear diff leak
