$#@%^&* windshield wiper/washer
Old May 29, 2002 | 02:21 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default $#@%^&* windshield wiper/washer
Mine sucks azz big time...the wipers are fine but the washer doesn't pump fluid to the windshield. When I remove the hose from the nozzle it squirts ok from one of the hoses but not the other :confused: :mad So now I have a big puddle of washer fluid in the garage floor. Anyone else have this problem???
Old May 29, 2002 | 02:46 PM
luvinc5's Avatar
luvinc5
Default Re: $#@%^&* windshield wiper/washer (pewter99)
It sounds like the hose is loose on the other wiper blade.
Old May 29, 2002 | 03:44 PM
pewter99's Avatar
pewter99
Default Re: $#@%^&* windshield wiper/washer (luvinc5)
All the hoses are connected and nothing is clogged so....WTF?...
Old May 29, 2002 | 07:46 PM
alanh's Avatar
alanh
Sounds plugged up to me :yesnod:
[Modified by alanh, 5:46 PM 5/29/2002]
Old May 29, 2002 | 10:34 PM
TenaciousD's Avatar
TenaciousD
Default Re: $#@%^&* windshield wiper/washer (alanh)
Same problem with the lower one on the driver's side on mine, haven't spent the time to pull it apart, seems the only way it wouldn't be working is if it is clogged, let us know what you find out. :cheers:
[Modified by TenaciousD, 9:35 PM 5/29/2002]
Old May 30, 2002 | 01:10 AM
Duck916's Avatar
Duck916
I never use the windshield washer--wouldn't even know if the thing works. :p:
Old May 30, 2002 | 09:35 AM
CP's Avatar
CP
Nope, got no puddle of washer fluid on my garage floor. Just looked. :lol:
Old May 30, 2002 | 09:40 AM
zoneblock's Avatar
zoneblock
C5 has a windshield washer :confused: :lol:
Old May 30, 2002 | 04:39 PM
gbm's Avatar
gbm
Something aint connected right or clogged and leaking because of it. Take it apart and find out
Old May 30, 2002 | 05:23 PM
pewter99's Avatar
pewter99
Default Re: $#@%^&* windshield wiper/washer (gbm)
Well after taking the thing apart, which is how I got the washer fluid all over the floor( kept cycling the pump holding the hoses pointing away from the car) I have determined that this problem will remain a mystery to me. I have taken every piece apart and blown air thru them to see if they were clogged...they weren't :confused: :mad when I cycled the pump fluid sprayed from one hose but not the other (there are 2 on each wiper) so I held my finger over the "good" side and repeated the process and guess what...thats right it worked :mad soooooo I tried again and only one side worked :mad :mad WTF!!!! I give up...its not like I use them alot in fact hardly at all its just that it irritates me that they don't work when I need them.
Old Jun 5, 2002 | 01:15 PM
gbm's Avatar
gbm
What a pain the the frickin butt. The pump must have something wrong with it, leaking when activated, but like you said, u don't use them that much, so wtf.
I don't like using them myself, simply because it sprays crap everywhere and gets your car dirty anyway..... :cheers:
Old Jun 5, 2002 | 04:49 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Not sure what to tell you...............but here's a problem I'm having. Even though I never use the washers, I keep getting a message on The DIC that tells me Washer Fluid is low. Can't find any leaks and I can't belive it's evaporating. :confused:
Old Jun 5, 2002 | 05:43 PM
TeeJay's Avatar
TeeJay
Default Re: $#@%^&* windshield wiper/washer (Mag Red Monster)
Mag Red Monster,
Once upon a time I hit [nudge or brush really] the sensor connection to the washer fluid reservoir and got that message next ignition. It's located at the 3 o'clock position when viewed from the left [convenient] fender. Give it an engaging push and the message should clear if not immediately, after a couple of ignition cycles.
Old Jun 5, 2002 | 06:41 PM
Mag Red Monster
Elite Member
Default Re: $#@%^&* windshield wiper/washer (TeeJay)
Mag Red Monster,
:cheers: I'll check that out!
Old Jun 5, 2002 | 06:45 PM
lostsoulny's Avatar
lostsoulny
Default Re: $#@%^&* windshield wiper/washer (TenaciousD)
drivers side lower just kinda oozes out
Old Jun 5, 2002 | 06:47 PM
lostsoulny's Avatar
lostsoulny
i suspect the pump is just kinda weak like alot of other electircal componetns on teh vette, gotta love how you can dim your lights when holding the power window switch up when with teh window closed :crazy:
Old Jun 5, 2002 | 07:15 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: $#@%^&* windshield wiper/washer (lostsoulny)
Yeah, that's complete poopiee. I can't believe how cheap the electrical system is...
:bs :mad
Old Jun 6, 2002 | 05:35 AM
pewter99's Avatar
pewter99
Default Re: $#@%^&* windshield wiper/washer (TexasRedY2K)
What could they cost, $5 bucks each?????
You won't believe this................ GM doesn't sell just the washer nozzles, you have to purchase the entire $70 wiper arm to get them!!! :nopity
So treat your washer jets with TLC, they are worth $35 bucks each. :(
:mad :mad :mad :bs well then I guess mine will NEVER work again for $70 they can K.M.A!!!
To $#@%^&* windshield wiper/washer
