I would like to lower the back of my 99 about a half inch, Too much room in the wheel well, I've seen more than one kind of lowering kit. Is one better than the other?
meanjoe,
The lowering kits that you see for sale, are for lowering the C5, lower than the stock bolts will allow.
Stock adjusters will allow a half inch drop.
These pictures may hopefully, allow you to further understand.
Here is a picture of your stock front & rear adjusters.
Fronts notice the large rubber bushing/pad.
Rear notice the 6-1/2" length of the bolt.
FYI, if you use longer bolts in the rear you're basically putting the car down on the bump stops in the shocks. Even the stock bolts allow it to be put low enough you will bottom out much easier.
You shouldn't just lower the back end. You need to maintain the rake. If you don't you can get air buildup under the car and it can handle funny at speed.
There is a right way to do it, and wrong way. Here is a link on how to do it right.
Remember that these cars are getting older, if yours has seen salt it may be very difficult to adjust the front spring adjusters. PB blaster could be your friend here. You should spray the front adjusters with it several times a couple of days before you do the fronts to make sure you will be able to move the adjusters.
They told me when I got this car to sign up here. And it's guys like you that are willing to take the time to help out other members that aren't as well versed on the thing we need to know that make Corvette ownership a whole lot more fun.
Thanks again to all of you guys that offer your time, opinion's and expertise.
