wierd electrical help
Old Aug 7, 2012 | 11:58 AM
nitrouspaul's Avatar
nitrouspaul
Default wierd electrical help
I have competed a motor swap and when i hook up the battery wierd stuff happens.
1 the radiator fan runs
2 the check engine light and foot well lights go on (no key)
3 starter turns ok when i turn it over
4 there is a small spark that comes of the ground straps when i touch them lightly to the block
5 with key on dic says reduced power,and fan turns off
i need help to diagnose please.
Old Aug 7, 2012 | 12:17 PM
dadaroo's Avatar
dadaroo
I will respond to #4. If the block is properly grounded back to the battery negative side(which seems like it is), and you have voltage in the ground strap circuit and touch it to the block you should see a spark since you are making the circuit complete. You should see the same thing if you touch the ground strap to the metal frame (assuming it is properly grounded back to the battery).
I'll have to ponder on your other issues for a while. Sounds like #3 is for info and not a problem. If so it would also indicate the block is properly grounded (I assume the starter is grounded via the block but am not positive (don't have a wiring diagram with me at this time).
Old Aug 7, 2012 | 12:48 PM
nitrouspaul
yes number 3 is for information purposes, so a spark from the ground strap on the rear of the drivers head is normal then. I checked everything the starter wires are ok the grounds are all on the battery is brand new(car sitting for 2 years inside) I understand bill curlee seems to think these cars have ground problems i am going to set about cleaning some of them thanks for the response need another brain here to help with diagnose proceedure. I have a multitester can i install it between the disconnected battery positive and the frame then if there is a voltage registering look for a short by pulling fuses one at a time to see what the offending curcuit is? or does anyone think it could all be caused by bad ground i do see a bit of green on the ground connector on the frame near the steering box.
Old Aug 7, 2012 | 01:25 PM
lucky131969's Avatar
lucky131969
Post your codes. Is the dimmer switch on? What is the condition of the ECT and associated wiring? How many wires do you have connected at G106(above the starter)?
Old Aug 7, 2012 | 01:37 PM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
Originally Posted by dadaroo
....If the block is properly grounded back to the battery negative side(which seems like it is), and you have voltage in the ground strap circuit and touch it to the block you should see a spark since you are making the circuit complete. You should see the same thing if you touch the ground strap to the metal frame (assuming it is properly grounded back to the battery).....
I don't understand.
Are we talking about the same thing?
All grounds should be at the same potential.
There should be no current flow between grounds. Any current/potential between grounds would be grounds for a ground loop. <vbg, I just thought that up. Am I too funny, or what?>
dan k.
Old Aug 7, 2012 | 02:04 PM
lucky131969
Originally Posted by photonhunter
I don't understand.
Why? Some devices are "hot at all times", and some are not.
Old Aug 7, 2012 | 02:57 PM
photonhunter
Lucky,
Once again, just to clarify, we are talking about a current flow between grounds?
If we are, it shouldn't matter whether a device is 'hot' or not. All grounds in a car should be at the same potential with respect to each other. Is this not correct?
I am not an electrical engineer specializing in autos with non-metallic bodies, so I'm prepared to be 'schooled' here, but how can you not experience ground loops with grounds at differing potentials?
dan k.
Old Aug 7, 2012 | 05:06 PM
lucky131969
Lucky,
dan k.
Suggesting that everything is at the same potential, is somewhat of a broad stroke. That would suggest that everything on the vehicle uses the same source voltage, which obviously is not true. I do not know what you mean by "current flow between grounds". The way I read this, he touched a ground wire to the block, and got a momentary spark....not uncommon, especially for a circuit that has battery voltage.....and depending on the load. Also, The car body could be made out of applebutter, since all the grounds connected to the chassis/engine block.
Old Aug 7, 2012 | 05:21 PM
SMaster's Avatar
SMaster
You wouldn't happen to have the ground that goes on the passenger side of the block, ABOVE the starter, on the starter lug would you?
There's a picture of the starter wiring in one of Curlee's threads I believe.
HTH
Old Aug 7, 2012 | 06:02 PM
lucky131969
Thus my question in post #4.....
Old Aug 7, 2012 | 07:44 PM
nitrouspaul
dimmer switch? i think you may be right it might be on i will check as for wires above the starter i only have the one heavy black ground off the battery going to the block is there another one on that side i missed the turbo hosing and such makes it very tight in there to see anything
Old Aug 7, 2012 | 07:48 PM
nitrouspaul
by the way none of this explains the fan running issue and as for dtc only reduced power low fuel low tire pressure but the last two are right on i have low fuel and low tire pressure car has been sitting for two years
s master i have 3 wires on the positive terminal of the starter splenoid. large red from battery,heavy rust colored,small black with white tracer and i am wondering what a black wire is doing on the hot side? the picture you elude to doesnt make it clear
Old Aug 7, 2012 | 08:01 PM
nitrouspaul
s master you got me looking for schematics of g106 and now i thinks i got the problem you eluded too. correct me if i am wrong but the black wire with white tracer goes to block and not the starter solenoid yes? I am such an *******
Old Aug 7, 2012 | 08:09 PM
lucky131969
good thing you brought that up SMaster.....
I'm out...
Old Aug 7, 2012 | 08:15 PM
AllVette's Avatar
AllVette
Old Aug 7, 2012 | 10:47 PM
nitrouspaul
great picture and a fine thing too because i had the thin black on the solenoid put it on the block and viola the problems went away, so after my heart stopped racing because I was nervous as heck from all the work and wondering did i forget something else, I started the car after 2 years of work in fact today is the anniversary and she fired right up no problems. Now i can enjoy the fruits of my labours and try for 1000 rwhp after the break in period, to all who chimed in tryin to help me your always welcome when passing by to stay at my house raid my fridge drink all my beer and sleep with my wife
Cheers
Old Aug 8, 2012 | 12:58 PM
dadaroo's Avatar
dadaroo
PhotonHunter: What I was trying to explain is if a circuit is powered, but the ground connection is not made you have no current flow. If you then touch the ground connection to the block (or anything else connected back to the battery negative then you should see a spark meaning you have now made a complete circuit. Just like you will see if you remove the negative battery connection and then reconnect it on the corvette since there are circuits that are "live" at all times.
Old Aug 9, 2012 | 03:08 PM
photonhunter
Okay, I see what you're saying now.
Thanks for the clarification, dad. <g>
dan k.
To wierd electrical help
