Fuel Experts Please! 99 Vortech/Built FRC
Old Aug 10, 2012 | 03:19 AM
Y2KRoadster's Avatar
Y2KRoadster
Default Fuel Experts Please! 99 Vortech/Built FRC
I have never heard of a problem like this before. Hopefully, one of you has!
My tuner I were out tuning the car tonight when we noticed two things after a while.
1) On a second gear pull, the car violently fell on it's face. It literally felt like someone was clamping the fuel lines off. It was not doing this earlier in the night!
2) During our third and fourth gear pulls, I had to get out of it because the car was leaning out up top; say, above 5000-5250 RPM's. It was not doing this a couple days ago.
Well, needless to say, we were baffled. Car runs and drives great under normal throttle! The car has an LPE pump, BAP, Racetronix harness, 60LB injectors, 100% meth, and is currently showing 10 PSI on a boosted low compression motor. Plenty of fuel right?
Here is the crazy part that makes no sense!
Car started having problems when we were showing a bit less than 1/2 a tank of gas. We called it a night to do some research. On the way home, I topped off the tank, and it took almost 9 gallons, so, I know that the fuel gauge was fairly accurate. With a full tank, the car does not fall on it's face anymore and the car also runs perfect up top...it's even too rich now because of the extra fuel we added...at 6K in 3rd and 4th, the A/F is 10.2-10.5 with the full tank and runs perfect (well, perfect for a car running pig rich!!
EDIT: One more thing. I let the gauge hit just below an 1/8th of a tank a few weeks ago and it actually ran out of gas...the factory pump was replaced with the LPE pump.
Can someone please tell me what the heck is going on?!?!?!?
Old Aug 10, 2012 | 03:35 AM
Lothar34's Avatar
Lothar34
Can you tell if your side-to-side pump is working?
Old Aug 10, 2012 | 08:05 AM
nullpointer's Avatar
nullpointer
How would someone do that?
Old Aug 10, 2012 | 03:58 PM
wrmiles's Avatar
wrmiles
Left tank, which feeds the engine, should remain near full as the right tank empties. This can be checked by monitoring the tank sensor output voltages with a Tech II or a voltmeter.
It may be possible that the jet pump circuit which pumps from right to left is not conpletely inoperative but is obstructed in such a manner that it cannot keep up with the increased fuel flow with your mods. I say this because your engine did not quite, which is what usually happens with no transfer at all.
Old Aug 10, 2012 | 04:50 PM
Y2KRoadster
Where is the tank sensor located? Thanks!
Old Aug 10, 2012 | 11:57 PM
wrmiles's Avatar
wrmiles
By tank sensor,I meant the fuel quantity senders, which are located on the back of each tank, accessible through a panel on the front of the rear wheel wells.
To Fuel Experts Please! 99 Vortech/Built FRC
