Ls6 intake question
Old Aug 10, 2012 | 09:18 PM
FRITZM's Avatar
FRITZM
Default Ls6 intake question
I have a 2000 vert. Does anyone know the difference between ls6 intake manifold part number 88894339 and 12573572? Purchased the first but received the second and not sure if it is correct intake for my 2000 vette ls1. Thanx.
Old Aug 10, 2012 | 09:23 PM
cptinjak's Avatar
cptinjak
Difference is 76320767.
Jack
Old Aug 10, 2012 | 09:26 PM
FRITZM's Avatar
FRITZM
Default Ls6 intake
And U R N AZZ. IF YOU CAN'T BE HELPFUL, GET LOST JERK.
Old Aug 10, 2012 | 09:28 PM
cptinjak's Avatar
cptinjak
And that is? I'm a relative noob.
I was being a d1ck and gave you the difference of those two numbers.
Seriously though, it is an LS6 manifold. That is the casting number, not necessarily a part number.
Jack
Old Aug 10, 2012 | 09:35 PM
baxsom's Avatar
baxsom
if it flat on the bottom it is an LS6 regardless of part #. curved is an 00 or older LS1.
Old Aug 10, 2012 | 09:40 PM
FRITZM's Avatar
FRITZM
Default Ls6
It is flat. It has a gm marked electrical connector on the rear next to the inlet for a hose. But there is a tag that says "made in mexico" though. Is this anything to worry about? I don't want to be keeping a obvious knockoff.
Old Aug 10, 2012 | 09:45 PM
cptinjak's Avatar
cptinjak
LOL calm down buddy. Read my post. The numbers are casting numbers of ls6 manifolds. You got the right part.
NOW GO YELL AT SOMEONE ELSE!!!
Jack
Old Aug 10, 2012 | 09:50 PM
FRITZM's Avatar
FRITZM
Default Ls6
Mea culpa to jack. Shot from the hip, so a bit edgy. Not a good feeling wondering if you have been ripped off. Also thanx to baxsom.
Old Aug 10, 2012 | 10:00 PM
cptinjak's Avatar
cptinjak
If you pretend to believe that I didn't have to google "mea culpa", then we'll call it even.
No worries man. You got the right stuff!
Jack
Old Aug 10, 2012 | 11:29 PM
NukeC5's Avatar
NukeC5
An LS6 is an LS6. The 572 came on the later models. Not sure why they changed numbers, but the runner length, plenum volume, etc are all the same in the different part numbers.
Old Aug 10, 2012 | 11:54 PM
FRITZM's Avatar
FRITZM
Default Ls6
I know that ls1 engine throttle bodies are drive by wire. This ls6 intake has bosses on the passenger side to enable, most likely, f-bodies to mount the tb cable and that is the only difference i could find.
Old Aug 10, 2012 | 11:57 PM
FRITZM's Avatar
FRITZM
Default Ls6
To capnjack: The numbers are not casting numbers they are, in fact, gm part numbers.
To Ls6 intake question
