Dumb Jacking Question
Old Aug 10, 2012 | 03:29 PM
171soon's Avatar
171soon
Default Dumb Jacking Question
Do you hesitate to jack your vette up on one side only, to change a wheel or brakes or what have you? I can imagine that over time, that twisting of the entire body and frame would loosen things up structurally, but maybe I'm letting my imagination run wild. I have more common sense than car knowledge. I would like to be able to carry around a compact jack and stand, but I am worried about the effect of uneven jacking over time. Any insight from the auto-tech inclined appreciated.
Old Aug 10, 2012 | 03:51 PM
dave89gta's Avatar
dave89gta
I wouldn't worry about it. I think normal driving puts far more stress on the body/frame than jacking it up at a single corner.
Old Aug 10, 2012 | 06:40 PM
baxsom's Avatar
baxsom
how much do you plan on jacking one corner only?
Old Aug 10, 2012 | 06:45 PM
moespeeds's Avatar
moespeeds
Goto the track sometime, everyone does it, constantly. If you jack from the rear puck it will lift the whole side, then just put a jackstand under the front and level it out. I also saw a guy jack the whole side from the center of the car, right where the seat mounting strap goes across. He just threw a piece of wood under there right where the strap meets the frame and jacked the whole side up.
Old Aug 10, 2012 | 07:53 PM
171soon's Avatar
171soon
This will be my main method of working on the car, so pretty often. I don't have a garage, driveway, or even level ground near my house (gotta love city living), so I am basically looking for a jacking solution that is VERY portable, which I can carry in the trunk of my civic, or in the vette if I absolutely have to. Then I can just find a quiet spot in a parking lot anywhere.
Old Aug 10, 2012 | 07:56 PM
171soon's Avatar
171soon
I see what you're saying. I guess it's at best not a big deal and at worst a necessary evil. That's what I was thinking, except I would want to use a scissor jack for the sake of portability. You see anybody using those rather than a floor jack?
Old Aug 10, 2012 | 08:22 PM
cptinjak's Avatar
cptinjak
Jacking from the side only won't hurt the car, but in my experience, it is simply easier to jack straight from the rear or from the front. This may not be true for all C5's but mine is low enough that a jack won't fit under the rocker panel anymore, so ANY jacking requires multiple 2x6s to drive up first.
Having broken a scissor jack and dropping my old volkswagen on my head, I am a strong advocate AGAINST scissor jacks. Use a real jack, multiple jackstands, wheel chocks, and check the stability before touching the car with a tool. You can never be too careful, and cutting corners for convenience while lifting your car is just asking for trouble. I should have died once, and I'll never skimp in this area again!
Jack
Old Aug 10, 2012 | 09:59 PM
jrose7004's Avatar
jrose7004
No problem with jacking one corner.
Old Aug 13, 2012 | 10:55 AM
waddisme's Avatar
waddisme
I use the center support when switching out pads and rotors for track days. Steel plate is big enough for my jack to fit into it. I also don't have to worry about forgetting to remove my jacking pucks
Old Aug 13, 2012 | 12:42 PM
Cybermind's Avatar
Cybermind
This is a non-issue as far as I'm concerned. I have never heard of a car frame damaged by jacking one corner at a time. If there were a frame that delicate, it would literally fall apart driving on the road.
However, I have heard that very early Lotus Elans could literally fall apart since the fiberglass body was an integral part of the structure.
Old Aug 13, 2012 | 01:43 PM
Corvette_Ed's Avatar
Corvette_Ed
Get yourself a set of the leave-in jacking pucks from Southern Car Parts, and make sure to use jack stands when possible to prevent possible injury and/or damage to your car. Other than this, don't worry about jacking one corner only. For the most part the suspension parts on the other three corners will react as if the car were driving over an uneven surface.
Old Aug 13, 2012 | 02:00 PM
wcsinx's Avatar
wcsinx
Forget the pucks
http://www.eliteengineeringusa.com/c...nd-mtg-screws/
Old Aug 13, 2012 | 02:11 PM
Corvette_Ed
Originally Posted by wcsinx
The pucks cost a quarter of what those would run, and can be installed in seconds. Those rails are nice, but they'd require lifting the car to install, which, for the OP, would be counterproductive as he'd require something to support the jacking point to jack it up. Something just like the jacking pucks.....
Old Aug 13, 2012 | 02:16 PM
waddisme's Avatar
waddisme
I have like $8 in my 4 jacking pucks - $1.50 for puck, $.50 for eye bolt and about 2 min each to drill and assemble.
Old Aug 13, 2012 | 02:25 PM
wcsinx's Avatar
wcsinx
You don't actually need pucks to jack a C5 contrary to popular belief. A simple piece of wood will suffice. As far as the investment of time, installing the rails on my C5 took me < 1 hour. Now I never worry about lifting my car. I just slide a jack under her and pump it up. The jacking pads are integrated into the rails.
Furthermore, those rails also protect you from high side damage. Mine have kissed a speed bump or two.
Old Aug 13, 2012 | 02:26 PM
171soon's Avatar
171soon
Point taken and I have zero interest in putting myself or the the car in danger. If I can't work out a portable enough solution, then I will have to sacrifice convenience etc and just depend on a local mechanic. I think I will just go down to harbor freight when I can and see what the options are.
Jack
Old Aug 13, 2012 | 07:57 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Correct method // joe
Old Aug 14, 2012 | 06:44 PM
bighank's Avatar
bighank
I leave them in the small compartment in the trunk.
Old Sep 9, 2012 | 01:17 AM
RLDaily's Avatar
RLDaily
I actually picked up a big hunk of an 18-wheeler tire on the highway, cut some pucks out with a bandsaw and Ta-Daaaaaaaaa, nice lifting puck.
Cost? $0.00
To Dumb Jacking Question
