Numerous DTC Codes & DIC Errors
Old Aug 12, 2012 | 06:18 PM
fkelly2's Avatar
fkelly2
1st Gear
Default Numerous DTC Codes & DIC Errors
When I start my car, I get the below. Any else seen this?
Corvette Problems
Check Tire Pressure
Service Active Handling
Reduced Engine Power
Service Vehicle Soon
Service Traction Control
Low Fuel
Check Engine Light
Fuel Gauge Fails Low
Oil Gauge Fails Low
Temp Gauge Fails High
Also AC Will Not stay on and RH Door (Window Door Locks Control Panel) does not work. And Seat Easy entry does not work, and FOB does not retain SYNC.
Codes
28 TCS
U1310 H U1016H
40 BCM
U1255 H C U1016 H C U1096 H C
58 SDM
U1301 H U1255 H
60 IPC
U1255 H U1064 H U1040 H U1176 H U1088 H
99 HVAC
U1064 H U1096 H U1160 H C U1255 H
AO-LDCM
NO COMMS
A1-RDCM
U1255 H U1064 H U1016 H U1096 H
A6-SDM
U1300 H U1255 H
BO-RFA
U1255 H U1064 H U1096 H U1016 H
Old Aug 12, 2012 | 06:46 PM
Casket86's Avatar
Casket86
How's the charge on your battery? I am new to the C5 forum, but have been doing alot of reading and I seem to recall a similar thread were the resolution was a weak battery.
Good Luck
Old Aug 12, 2012 | 09:30 PM
flynhi's Avatar
flynhi
clean and tighten all grounds in engine bay
To Numerous DTC Codes & DIC Errors
