HELP - new column lock issue :(
Old Aug 14, 2012 | 12:56 PM
CaptainCrunch's Avatar
CaptainCrunch
Default HELP - new column lock issue :(
All,
I have a 2002 M6 coupe that is no stranger to column lock issues - last year I got stranded soon after purchasing the car that required a tow to the local dealership. They were able to unlock the column and fixed the issue by removing the lock itself so that the column doesn't lock even with the car off and the alarm on. Problem solved, so I thought.
I had the car in the dealer this morning to fix an issue with my power seat switch that was draining the battery, and after they fixed this issue they went to move the car out of the work bay and the thing kept shutting off at 1-2 mph. The column is not locked, but apparently the car thinks that it is and won't let anybody drive it. They have tried flashing the computer, disconnecting/reconnecting the battery, and pulling fuses 5 and 23 for about 10 minutes and none of this has made the car drivable. They are out of ideas and so am I, so I was hoping someone here had a suggestion!!
Thanks in advance,
Tommy
Old Aug 14, 2012 | 12:59 PM
lucky131969's Avatar
lucky131969
Originally Posted by CaptainCrunch
All,
Thanks in advance,
Tommy
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Aug 14, 2012 | 02:08 PM
Trios's Avatar
Trios
Oh man, that's such a great thread right there. Wouldn't it be great if it were at the top of the C5 tech page? You know, right there at the beginning of the forum, where anyone who needs help with column lock information could easily see it, and potentially click the link and save us from innumerable column lock threads?
Wait a second...
Old Aug 14, 2012 | 04:26 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
All,
Nope, thats only half a fix. You now need to set the Fuel Cutoff MPH to 255. Default is 2mph. But this cant be done by dealer. You need to find a LSX shop with HP Tuners.
Old Aug 14, 2012 | 04:32 PM
Corvette_Ed's Avatar
Corvette_Ed
The LMC5 eliminates the need to do this...
Old Aug 14, 2012 | 04:46 PM
lucky131969
Hmmm....how exactly?
Old Aug 14, 2012 | 04:52 PM
Trios's Avatar
Trios
The fuel shutoff is to prevent the car from moving when the computer thinks the column is locked, so some idiot doesn't drop the clutch and run into a wall when he can't turn the wheel.
The LMC5 provides the "column is unlocked" signal to the computer so that the computer will not shut off the fuel; it takes the actual column lock actuator and any installed K harness entirely out of the wiring system when doing so. The column remains unlocked at all times, and the LMC5 provides a fake "locked" or "unlocked" signal to the computer as necessary.
Old Aug 14, 2012 | 04:54 PM
Corvette_Ed
You'll have to ask Richard that question; he's the one who knows how it works.
Old Aug 14, 2012 | 04:57 PM
lucky131969
Well, I just don't know Dick. .......
Old Aug 14, 2012 | 05:04 PM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
The LMC5 simulates a perfectly functioning steering column lock system to the BCM. I installed one several months ago and the issue has not returned.
Old Aug 14, 2012 | 09:11 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Default column lock issue
I found this interesting:
http://www.corvetteactioncenter.com/...-debunked.html
Old Aug 15, 2012 | 09:44 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
http://complianceparts.com/lmc5description.html
But in case it doesnt you always have a sure fix with HP Tuners or EFI Live
To HELP - new column lock issue :(
