tb hose?
Old Aug 14, 2012 | 09:40 PM
04blackice's Avatar
04blackice
Default tb hose?
Im putting a ported tb on my 04 z and the new one has a fitting blocked off.its the one that goes to the valve cover.so the small elbow on top of tb to the valve cover.is this a must or is it ok blocked off.thanks
Old Aug 14, 2012 | 09:47 PM
vettenuts's Avatar
vettenuts
That is what feeds clean/filtered air to the PCV system. Yes, it is required. Otherwise you need another source of filtered and metered air.
Old Aug 14, 2012 | 09:59 PM
04blackice's Avatar
04blackice
Well the stock has a push in type.and the new one has threaded.so i cant put the elbow in..what are my options...a small filter on the hose end.or jb weld the elbow on..help please
Old Aug 14, 2012 | 11:12 PM
04blackice's Avatar
04blackice
Well solved my own problem.auto zone had the perfect size fitting.thanks
To tb hose?
