Half shaft install? stuck.
Old Aug 18, 2012 | 11:56 AM
mitchcole's Avatar
mitchcole
Default Half shaft install? stuck.
In the process of putting the car back together again after a clutch job. The half shafts really don't want to go back in.
The outer CV joint is at a pretty extreme angle and doesn't want to rotate. Does it bind at a certain point? I can't get these parts back together.
Any thoughts? photos?
Old Aug 18, 2012 | 12:10 PM
mitchcole's Avatar
mitchcole
Forget it... The answer is to load up the suspension with a jack to get the angles straight. Slides right in...
Old Aug 18, 2012 | 12:42 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Spray some lube on the end--try to get the angle as str8 as possible--
Old Aug 18, 2012 | 09:37 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Check to make sure that the retaining ring is properly seated in the end of the half shaft spline area. Liberally lube this spring clip and the shaft splines so it slides in easily. Also spread some lube on the rubber of the half shaft seal on the side of the differential to avoid tearing. Align the halfshaft - keep it straight - make sure splines are proplerly lined up. Use a rubber mallet on the end of the shaft to persuade the clip to slide in and seat. It sometimes takes a FIRM wack with the mallet to get it to pop in place. Reassemble the outer hub and spindle and you are done.
Old Aug 18, 2012 | 10:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had the same issue and once the car was on the ground and I rolled it forward and back, it popped right in.
Bill
To Half shaft install? stuck.
