found the culprit
Old Aug 24, 2012 | 01:05 AM
michaelfrench's Avatar
michaelfrench
Default found the culprit
Well guys I found the issue, will order parts tomorrow..... Looks like I snapped my aftermarket hardened mainshaft yet again!!! Now my money will be going towards shocks, braces etc.... To make my car hook and not wheel hop. Then ill worry about go fast goodies lol.... Anyways onto pics....
Old Aug 24, 2012 | 01:33 AM
Chilliwack vettes's Avatar
Chilliwack vettes
I would have thought that something else would break first before that part!
Old Aug 24, 2012 | 07:50 AM
jsbzoh6's Avatar
jsbzoh6
Ouch.. having had one of those repairs already, I feel your pain. Good luck getting everything put back together.
Old Aug 24, 2012 | 07:55 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I feel your pain....both for the broken parts and for having to work outside in the driveway.
Old Aug 24, 2012 | 12:14 PM
zeevette's Avatar
zeevette
If you don't control wheelhop, there's no "safe" driveline part.
Old Aug 24, 2012 | 12:37 PM
NukeC5's Avatar
NukeC5
Can anyone give a list of all parts that should be replaced to avoid wheel hop? I have an A4 with a 3.42 rear end and soon a high stall converter. The stress on the drivetrain is a worry to me.
Shocks, springs, bushings... what else?
Old Aug 24, 2012 | 01:58 PM
Bluefire's Avatar
Bluefire
My Coupe has an A4, 3:42's, 2800 stall, 421 rwhp. IMHO the best thing I did to reduce wheel hop was adding Pfadt coilovers (i.e. losing the leaf springs). It also stopped the inherent rear-end swing out to the right when breaking the tires loose.
Old Aug 24, 2012 | 03:01 PM
chaase's Avatar
chaase
St. Jude Donor '12
Old Aug 24, 2012 | 03:05 PM
chaase's Avatar
chaase
St. Jude Donor '12
That is my configuration and with drag radials and a fair number of passes down the 1/4 mile nothing has broken. I have the hardened output shaft and that is it.
You have to pay attention to the car and shut it down when you get wheel hop though. It is difficult to completely abolish wheel hop so it is important to know the signs and back off.
Old Aug 24, 2012 | 09:35 PM
76 VETTE's Avatar
76 VETTE
Good luck!
Old Aug 24, 2012 | 09:56 PM
NukeC5's Avatar
NukeC5
Ya, Ill be very careful till I get used to it then.
Old Aug 24, 2012 | 10:03 PM
76 VETTE's Avatar
76 VETTE
I had wheel hop after owning my 01Z for 2 years.Never had it before.After a new set of rear tires I never had it again.Knock on wood!
Old Aug 26, 2012 | 10:22 PM
michaelfrench
i have a sticky tire and i launch hard.... transmission only had 20k miles... i have a built diff. the mainshaft was an upgraded one as well... going to invest in a pfadt brace as well....
car is an 02 btw... its not so much "wheel hop" its the drivetrain shake
Old Aug 26, 2012 | 11:30 PM
jrose7004's Avatar
jrose7004
Yep, you certainly snap that one alright!
Old Aug 27, 2012 | 10:37 PM
michaelfrench
sooo looks like ill be ordering the gforce 9310 mainshaft straight from them, hopefully next week
Old Aug 27, 2012 | 11:04 PM
Katherinejjm's Avatar
Katherinejjm
Old Aug 28, 2012 | 10:31 AM
NukeC5's Avatar
NukeC5
Im not sure if this was an answer to my question.. The image is not showing up.
To found the culprit
Old Aug 28, 2012 | 11:37 AM
dadaroo's Avatar
dadaroo
At least it seems like you are capable at wrenching. Should save you a lot of money and you should know everything was done "correctly". Too bad you can't do it in a garage.
Old Aug 28, 2012 | 01:49 PM
michaelfrench
yah, it takes me about 20 mins to pull a diff and about 20 mins to pull the transmission.... its actually really easy once you've done it as many times as i have
Old Aug 29, 2012 | 01:55 PM
zeevette's Avatar
zeevette
I recently put my Z back together after shattering my stock diff. I added an ECS trans brace, and a Pfadt diff mount/brace, and per instructions, removed the factory dampner. I can't definatively say my wheelhop is gone, because I'm still driving it pretty easy. I have broken the tires loose for about 100 feet or so, and rather than still needing to counter-steer to the right to stay straight, there was no hop/shudder that I could feel. That was at about a 50 roll. I've never gone hard from a dig, (on this car) because it'd just spin anyway, and tires are expensive.
