What Trans and Diff fluid??
Old Aug 24, 2012 | 11:51 PM
skeeters65's Avatar
skeeters65
Default What Trans and Diff fluid??
Doing the clutch on my car this week. While its all out I am going to put new fluid in there.
What fluid do you guys recommend and how much do each take?
Old Aug 25, 2012 | 01:32 AM
Lothar34's Avatar
Lothar34
Misread.
Info should be in your owner's manual. Any Dexron-III ATF for the transmission and 75w90 plus 4oz of friction modifier for the diff.
This dude has instructions:
http://mysite.verizon.net/res0aae8/webpage.html
Old Aug 25, 2012 | 01:41 AM
skeeters65's Avatar
skeeters65
Like I said in the title. Transmission and differential fluid.
Old Aug 25, 2012 | 08:21 AM
baxsom's Avatar
baxsom
thats why the previous poster said dex III ATF an 75w90 plus friction modifier in the diff.
i used amsoil tqd for transmission and gear drive for the diff.
Old Aug 25, 2012 | 09:03 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Dont use synthetic, yours is a 98 model.
Old Aug 25, 2012 | 09:24 AM
skeeters65's Avatar
skeeters65
Mine is a 2001.
That poster changed his post After I responded.
Old Aug 25, 2012 | 09:58 AM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I used Amsoil Torue Drive in the trans on my 2001, you'll need a gallon and fill till it comes out of the fill hole, you'll have a little left over.
I used GM's current 75w90 LS gear oil in the diff - it already has the friction modifiers in it. You'll need two quarts and fill the same way as the trans. Their is plenty of info here on other products and the quantities and procedures.
Old Aug 25, 2012 | 12:18 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Mine is a 2001.
As long as your trans doesnt have paper blocker rings, you can use synthetic.
Old Aug 25, 2012 | 01:00 PM
NukeC5's Avatar
NukeC5
Agreed, Ive heard of all kinds of issues when going with anything other than stock on the older models.
To What Trans and Diff fluid??
