Fuel filter
Old Aug 28, 2012 | 11:49 AM
dezcapt51's Avatar
dezcapt51
Default Fuel filter
Location of filter and any tips for changing would be appreciated.
2000 coupe
Old Aug 28, 2012 | 12:01 PM
lucky131969's Avatar
lucky131969
2000 coupe
I did a google search for "C5 fuel filter location", and came up with numerous hits....including the one below:
http://www.google.com/url?sa=t&rct=j...0rP036-GD6oIRA
Old Aug 28, 2012 | 12:09 PM
dezcapt51's Avatar
dezcapt51
Old Aug 28, 2012 | 04:50 PM
Cybermind's Avatar
Cybermind
I just changed mine this morning and I have to admit, it was the easiest fuel filter change I ever did. I was expecting alot of fuel to spill out and all I got was a trickle. The quick disconnects made the process even easier. Make sure you have a 3/8 quick disconnect tool for the metal disconnect. The plastic ones are disconnected by pressing the tabs.
Old Aug 28, 2012 | 06:23 PM
bighank's Avatar
bighank
Default Hope you changed the plastic locking tabs or you might have a flood
One of my tabs had disintegrated so much that the fuel gushed out and ran on the left muffler. Replaced both plastic tabs that came with the new filter. Mine was 10 years old when it failed,
Old Aug 29, 2012 | 06:25 AM
Cybermind's Avatar
Cybermind
My tabs were in excellent shape. They were flexible with no brittleness at all so I reused them. The funny thing is that the GM service manual does not mention anything about changing them.
Old Aug 29, 2012 | 11:54 AM
dezcapt51's Avatar
dezcapt51
Thanks, I guess no need to disconnect battery or remove fuel cap to relieve pressure.
Old Aug 29, 2012 | 12:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Battery disconnect not necessary and removing the fuel cap does nothing. There's a check valve in the line.
You want to relieve fuel pressure up front at the schrader valve on the fuel rail first. I just wrap a rag around it and depress it with a small screwdriver.
Old Aug 29, 2012 | 07:55 PM
bighank's Avatar
bighank
Default good luck mine is a 98 and one tab was really bad
I'm good for another 10 years.
Old Aug 30, 2012 | 07:19 AM
Cybermind's Avatar
Cybermind
The battery disconnect is only a precaution against someone starting the car while your under there. Or, if you need to use some sort of electrical power tool which is not recommended anyway when working on the fuel system.
To Fuel filter
