Dreaded service tcs abs. Pulled the code
Old Aug 28, 2012 | 04:32 PM
SLOWBRAH's Avatar
SLOWBRAH
Default Dreaded service tcs abs. Pulled the code
Code reads c1214 c h. Guessing that's an ebcm? Past and obviuosly current issue. Any cheap options to get her fixed?
Old Aug 28, 2012 | 04:45 PM
Cybermind's Avatar
Cybermind
Yep, that means that your EBCM needs to be rebuilt. That code is usually caused by a bad relay inside the EBCM. Your best option is to send it for a rebuild. You can go with ABSFIXER or Modulemaster.com. Or, you can fix it yourself if you feel up to it.
Old Aug 28, 2012 | 08:56 PM
1965markaccount's Avatar
1965markaccount
http://forums.corvetteforum.com/c5-t...r-fleabay.html
try this. lots of people have had a lot of luck with this fix.
Old Aug 28, 2012 | 08:57 PM
fishingdan's Avatar
fishingdan
St. Jude Donor '10 thru '24
I used ABS Fixer and have been pleased with the results. That's been about 8,000 miles ago.
Old Aug 28, 2012 | 10:19 PM
SLOWBRAH's Avatar
SLOWBRAH
Thanks!!!!
To Dreaded service tcs abs. Pulled the code
