check engine light
Old Aug 30, 2012 | 12:29 PM
radman98's Avatar
radman98
8th Gear
Default check engine light
I get an intermittent check engine light on a 1998 corvette and when I scan it, it comes up po705. (Trans range switch) If I read correctly this code may have something to do with starting, which happens. It acts like a bad fuel pump or fuel pressure regulator. I have replaced the pump and don't see anything wrong with the regulator. Has anyone experienced this?
