Just passing on some info.
Old Aug 30, 2012 | 08:15 PM
big454blockchevy's Avatar
big454blockchevy
Default Just passing on some info.
I've seen that our vettes with a bad oil sending unit usually alert us of our inoperative sending unit by pegging the oil pressure gauge . Well , mine took a crap yesturday when driving about 20 miles away from home. I noticed the service engine soon message and "low oil pressure" . I freaked out stopped then kept driving in a section of the highway that I didn't really want to be stranded in . Took a risk by continuing to drive it and of coarse if it had been truly a low oil pressure condition I would have done harm to the engine. At that point I continued to drive home and just changed out the sensor the following morning . The point I am trying to make is that the guage doesn't have to show a pegged psi needle only , it can also be a zero oil pressure indication for it to be the oil sending unit.
Old Aug 30, 2012 | 08:41 PM
Vicarious.'s Avatar
Vicarious.
Thank you for the tip. I had always heard it would peg the needle upon failure.
Old Aug 30, 2012 | 09:00 PM
gotz06?'s Avatar
gotz06?
The second time mine quit working it was also at 0
To Just passing on some info.
