oil in intake
Scott
not much more to say.
start with a vacuum test, see if there is any flutter in the gauge. if there is a leakdown test will show you the low cylinder
as stated the other possible is a crankcase that's unable to vent and or your catch can is routed incorrectly. a closed catch can needs to be routed to manifold vacuum. vented catch cans do not. if you're filling a vented catch can there is a good chance you have a good deal of blow by.
does this engine burn a lot of oil? like more than a quart per 1000 miles?
The catch can elimanited almost all of my oil in the intake issues.
I agree,, make SURE that you dont jave ANY other machancial issues.
Try just adding a catch can to your C5!
BC
NassyBlue, the pcv is set up like your diagram, except that the pcv valve is in the valve cover; would the placement of the pcv valve after the catch can have any effect on the catch can filling up very quickly?
RonSSNova, I am not sure about baffles, will check and get back to you. Valve covers bought from ebay, so may very well not have baffles.
racebum and lucky131969, no compression test or leakdown performed, but I can tell you that when we removed the old heads, we could still see the cross-hatching on the cylinder walls. I told him to perform a compression test, just to eliminate it from the equation, hasn't been done yet, though.
Thank you to everyone for your input, it has given us a few directions to go in; If we ever get it sorted out, I'll let you guys know.
Keep the shiny side up!
scott
scott
The lack of a properly baffled valve covers will for sure cause excessive PVC oil consumption. Make SURE you carefully check that out!!
You can also do a quick check for excessive piston blow by just by removing the oil fill cap when the engine is idling. With a properly operating PVC system,, you should NOT have any air out flow thru the opening of the oil fill spout.
Bill
Original poster stated in post #1 ...he has a catch can already installed... It's at maximum capacity after only 100 miles of driving.
http://forums.corvetteforum.com/auto...oot-cause.html
I am currently leaning towards routing the valley cover port to catch can and then thru breather. You can even drain your catch can thru dipstick back into motor. This also means expelling gases into atmosphere and plugging the intake port. Why take a chance with oil getting back into combustion chamber. Your inspection rules will have a lot to do with your choice. Good luck with it.
scott
Bill
