Squeeking Steering Wheel
Old May 31, 2002 | 07:40 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Squeeking Steering Wheel
Could someone talk about how they fixed thier squeeking steering column when turning at slow speeds? I dont want to take it to the dealer if there is an easy fix...
thanks!
Old May 31, 2002 | 10:13 PM
MDT's Avatar
MDT
Default Re: Squeeking Steering Wheel (kewlbrz)
kewlbrz,
I think.....c4c5specialist posted a long while back about how to apply some lube to the bottom bearing in the column.
Good luck.
Mark
Old May 31, 2002 | 10:30 PM
MDT's Avatar
MDT
Default Re: Squeeking Steering Wheel (MDT)
kewlbrz,
I searched the archives and it was C-5 TECH that made the post about lubing the steering column bushing. His post follows:
C-5 TECH
Senior Member
1481 posts [100%]
FLORIDA
Re: Lower bearing location on C5 steering column (Blackjetvette97) 7:21 AM 5/9/2002
The upper and lower column bearings are up high in the column...It is the lower column nylon bushing that makes the noise.The bushing is incased in the big gray rubber grommet visable under the hood at the firewall,were the steering shaft is.If you are good at getting into tight places,spray some white lithium grease behind the grommet...For best results,remove the steering shaft and pop the grommet out to lube the bushing (dont rotate the steering wheel with the shaft removed )...
Good luck.
Mark
Old Jun 1, 2002 | 01:27 AM
kewlbrz's Avatar
kewlbrz
thanks alot!
To Squeeking Steering Wheel
