many codes and poor performance
Old Sep 2, 2012 | 10:51 AM
pharestutt's Avatar
pharestutt
Default many codes and poor performance
last night after changing rear wheels my car did not want to move in first gear it also doesnt go into overdrive when driving normally and at WOT the car is very very weak i pulled these codes off the dic
PCM
P0102
P0412
P0418
P0443
P0740
P0753
P0758
P1518
P1571
P1644
P1860
Old Sep 2, 2012 | 10:57 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Was there an "H" (History) or a "C" (Current) after these DIC codes?
Did you attempt to erase them and see which ones come back?
To clear the codes let it automatically cycle through the codes then it will come to (MANUAL DIAGNOSTICS) this is where you can clear codes.
Use the options button to scroll forward and the TRIP to scroll backward find the code(s) to be erased. Check your connections.
To erase, press and hold the reset button until it says "NO CODES". To exit the Diagonstic menu press the METRIC BUTTON.
You can find a list of DIC code descriptions here.
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
sounds like you knocked a connection loose
Old Sep 2, 2012 | 02:14 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Try clearing them 1st they may all just be "false codes " most Autozones will read and clear codes for you for free---
Certain codes or combinations of codes will make your ECM go into a "protection mode" or reduced power mode---would explain the poor performance---
Old Sep 2, 2012 | 04:15 PM
pharestutt's Avatar
pharestutt
In found out my car is blowing the # 19 ign fuse every time I switch on ignition
Old Sep 2, 2012 | 04:17 PM
pharestutt's Avatar
pharestutt
All are current codes
Old Sep 2, 2012 | 05:25 PM
Coach62's Avatar
Coach62
St. Jude Donor '12
I'd research each code individually and see what they might have in common
Old Sep 3, 2012 | 07:48 PM
dannyman's Avatar
dannyman
A list of codes should help!
http://www.stengel.net/diccodes.htm
Dan
To many codes and poor performance
