Leaky Butt
Old Sep 6, 2012 | 09:03 PM
Chris Stewart's Avatar
Chris Stewart
Try another seal? Hey that's a nice looking diff brace. I had one just like it.
Old Sep 6, 2012 | 11:18 PM
2_60b4u's Avatar
2_60b4u
Originally Posted by ZeeOSix
Means the seal lips are either: a) damaged, b) have debris on them, or c) the axle might have a nick/flaw where the seal lips ride.
I just learned tonight that the reman axles where it slips over the output shaft is sometimes machined too far and it doesn't seal properly. I ordered up a OEM axle today, I'll report back if that fixed it.
This is the second seal already The brace is working out great, thanks again! Hopefully we can get together before winter.
Old Sep 7, 2012 | 01:13 AM
ZeeOSix's Avatar
ZeeOSix
Sounds like you found the problem.
Old Sep 7, 2012 | 01:28 AM
wcsinx's Avatar
wcsinx
First I've heard of that. Do you still have the old one? If so put a caliper on it and see.
Be sure there are no burrs or grit on the shaft. Wipe it down really well. You want it clean clean clean. Then put a thin coat of oil on it, and slide it straight in. It's pretty easy to screw up those seals if you're not careful.
Old Sep 12, 2012 | 06:40 PM
2_60b4u's Avatar
2_60b4u
Just put in a OEM cv axle and no more leaks.
Old Sep 13, 2012 | 12:02 AM
rockdude's Avatar
rockdude
I'm looking at this forum because my '01 has developed a leak seemingly around the axle housing where the axle enters the diff. I'll check it out this weekend.
Old Sep 13, 2012 | 10:00 AM
2_60b4u's Avatar
2_60b4u
There's lots of good info in this thread on where to start. Post up what you discover.
Old Sep 13, 2012 | 10:59 AM
Schubs's Avatar
Schubs
What is the part number on the new seal?
Old Sep 13, 2012 | 11:10 AM
bumble-z's Avatar
bumble-z
Originally Posted by schubs
what is the part number on the new seal?
gm# 88996703
Old Sep 25, 2012 | 10:05 AM
Dave 127's Avatar
Dave 127
I have 2004 left side leak what would the Dealer charge for this repair?
Old Sep 25, 2012 | 10:06 AM
Dave 127's Avatar
Dave 127
Default leaky butt
what would the dealer charge for this repair
Old Sep 25, 2012 | 12:33 PM
bumble-z's Avatar
bumble-z
Call them & find out???
Once you find out, report back with your estimate....Sound fair?
Old Sep 25, 2012 | 12:38 PM
  #33
Schubs's Avatar
Schubs
well that all depends, the axle seal calls for 2.5 hours to replace, so what the dealer charges will determin that let say they charge $120
LABOR=$300.00
SEAL = $26.75
FLUID= $70.16
TOTAL=$396.91
Old Sep 30, 2012 | 07:06 PM
  #34
Dave 127's Avatar
Dave 127
Default dealer cost for seal replace
Called a dealer today said 1 side would be $600.00
Old Sep 30, 2012 | 07:13 PM
  #35
Dave 127's Avatar
Dave 127
Default vent
Originally Posted by megawatt1203
I had the driver side seal and O-ring replaced on my 2000, seemed to be OK for a while, Took some spirited runs and the leak reappeared. Lived with it for a year or so when I read about the Diff vent sticking. Removed the spring and upper housing from the vent and clamped a rubber hose to the vent. It has been several months and some hot spirited runs and no leak. Do a search for the write up, this has worked for a lot of forum members. If the differential does not vent it builds up pressure and can leak from the seals. Good luck!!
do you have some pictures
Old Sep 30, 2012 | 07:42 PM
  #36
bumble-z's Avatar
bumble-z
Vent....
http://forums.corvetteforum.com/1578674331-post9.html
