spark plug torque
Old Sep 6, 2012 | 09:11 AM
Irish Whiskey's Avatar
Irish Whiskey
Default spark plug torque
what is the correct spark plug torque (ft.lbs or ft.inches??) for the plugs in a 2000 coupe??
Old Sep 6, 2012 | 09:16 AM
vettenuts's Avatar
vettenuts
11 lb-ft for second and subsequent installations. If the heads were brand new, the value is 15 lb-ft.
Old Sep 6, 2012 | 09:27 AM
3boystoys's Avatar
3boystoys
Wow, someone torques spark plugs, ought to be interesting on #7 getting a torque wrench even close.
Old Sep 7, 2012 | 09:17 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by 3boystoys
Wow, someone torques spark plugs, ought to be interesting on #7 getting a torque wrenc even close.
Skill and patience, my friend.....
I don't understand why so many people think that #7 on a 'Vette is so tough. My first brand new car was a '71 Chevelle SS455. Now on THAT car, #7 was tough!! My neighbor had a '68 Chrysler Imperial, with a 440 in it. We tuned it up once, and had to go underneath, and contort all over the place, to get #7....
Old Sep 7, 2012 | 09:39 AM
3boystoys's Avatar
3boystoys
My point is that it's kind of a waste of time. You torque on the oil drain plug too?
Old Sep 7, 2012 | 06:56 PM
leadfoot4's Avatar
leadfoot4
You screwing spark plugs into aluminum heads. Their threads aren't as forgiving as iron heads are.
Old Sep 7, 2012 | 07:05 PM
vettenuts's Avatar
vettenuts
Torque values are there to establish a correct preload in the threaded joint. I use a torque wrench for every part that is removed and has an established torque value.
On the oil drain plug, BMW makes their drain plug hollow so if someone doesn't torque it correctly it will fail the plug and not the pan. There is good reason for their design logic.
Old Sep 7, 2012 | 08:34 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Why, yes I do. 18 lb/ft IIRC.
Old Sep 10, 2012 | 03:38 PM
3boystoys's Avatar
3boystoys
Not on my BMW.
Old Sep 10, 2012 | 04:15 PM
LoneStarFRC's Avatar
LoneStarFRC
Default On Tapered seat plugs
Why, yes I do. 1/16th turn after plug makes contact with head.
Old Sep 10, 2012 | 06:02 PM
Czarvette's Avatar
Czarvette
Spend 2 minutes to unbolt the AIR valve near cylinder #5 and pull off the 1" rubber hose leading to it. The rest of the AIR hose and tubing can now be tucked away underneath the power brake vacuum canister, making access to #7 a LOT easier. It only took a spark plug socket and short extension bar (about 2") snapped onto torque wrench to reach #7.
BTW, I bought a 3/8" inch-pound torque wrench from CDI (division of Snap-On tools). It's about 12" long (the size of a Craftsman 3/8" ratchet) and it handier for the confines of an engine compartment than 18" long torque wrenches.
Old Sep 10, 2012 | 08:29 PM
cadmando18's Avatar
cadmando18
Awesome info as I am about to change the plugs and do a general tune on my 2001 vette.
Also, I'll stand up for anyone who wants to use a torque wrench. Even though I don't use one on everything, I can say that it's better to ask than to guess and be wrong.
Old Sep 13, 2012 | 09:52 PM
bighank's Avatar
bighank
Default I torqued by feel. Been doing that for 50 years
Getting a torque wrench on some of the plugs is next to impossible.
I torque by FEEL and have never had any problems with dozens of cars in 50 years. I also used some anti-sieze which GM does not recommend.
I do. Nothing worse than a seized or broken plug.
To spark plug torque
