car just shuts off?
Old Sep 8, 2012 | 09:19 PM
derekguzz's Avatar
derekguzz
Default car just shuts off?
99 vert. I put it in reverse sometimes and she just shuts off. I have o starting problems. New plugs, wires, battery, fuel filter, fuel pressure is good and holds once the car shuts off. I have no idea whats up. Its once in a while.
Old Sep 8, 2012 | 09:40 PM
derekguzz's Avatar
derekguzz
auto sorry. NO codes at all. I forgot to look at the gauges when it shuts off. I will pull vacuum and check around the engine to see if theres a ground issue or hole in a rubber hose. I get no engine stumble or anything. Ill pop it in reverse and a second later she just shuts off.
Old Sep 8, 2012 | 09:42 PM
derekguzz's Avatar
derekguzz
and all those buttons hes pushing are not repsonding in my car. Thats another problem I am looking into. So I have to use my scanner.
Old Sep 8, 2012 | 11:36 PM
derekguzz's Avatar
derekguzz
So what fixes the 2mph fuel shut off issue
Old Sep 8, 2012 | 11:50 PM
derekguzz's Avatar
derekguzz
Just read on another forum that to test if the recall was done, try to turn the wheel with key out and in park. If it turns then the recall was done. I checked and it turns....
Old Sep 9, 2012 | 10:25 AM
derekguzz's Avatar
derekguzz
I will check codes again and If I cant pull them, I'll get someone with a good scanner to try.
To car just shuts off?
