fuel level senders
Old Oct 2, 2013 | 01:45 PM
Chris Arnold's Avatar
Chris Arnold
If you're at 1/3 of a tank, an 18 gallon tank should take 12 gallons.
Old Oct 3, 2013 | 12:19 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Chris Arnold
I'm getting a code 1432 in my DIC. It supposedly means low fuel sender voltage. I just replaced the fuel sender on the passenger side tank and I wanted to know if there is a fuel sender also on the driver side tank and if the part numbers are the same for those senders.
the tank is showing less than half full when I fill it up. Then I never make it more than a couple miles before the fuel level read empty
yes...
Techron concentrate helps dissolve sulfur deposits on the fuel cards...in most cases, that's the problem...
Old Oct 3, 2013 | 09:54 PM
Yellow74c3's Avatar
Yellow74c3
I hope the Techron works for me, it sounds like I will need to run it thru numerous times to solve the issue......Fred
Old Oct 4, 2013 | 09:25 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
It took a good while for the sulfur deposits to build up and it will take a while to dissolve the sulfur with Techron concentrate...in most cases it solves the problem...may cost a bit but it will work...
