Started clutch install
Old Sep 9, 2012 | 12:57 PM
skeeters65's Avatar
skeeters65
Default Started clutch install
Well a buddy and I started my clutch install yesterday. So far it hasn't been so bad.
From putting it up on jack stands to having the complete rear cradle, diff,trans and torque tube out it only took 2hr 45 min!!
We noticed that the driver side out put shaft seal was leaking (leaky butt).
So we pressure washed the complete assembly and took it apart to replace the shaft seals and fix the leak between the trans and diff. Just needed anerobic sealer. Also installed a Pfadt trans mount.
Just have to get the shaft seals tomorrow and install them.
Then put it all back together!!
All in all so far it hasn't been too bad. Got about 5 hours into it so far.
I will update this when we are done.
I got a copy of the GM clutch swap instruction and they tell you to take WAY TOO much stuff apart. Don't follow them to a T. Use them as a guide and use common sense.
Old Sep 9, 2012 | 01:16 PM
Paul 75 L82's Avatar
Paul 75 L82
Good luck, that's the only thing that I paid someone to do on one of my cars. I just didn't want to take that on in a 2 car garage.
Old Sep 9, 2012 | 02:42 PM
CTD's Avatar
CTD
No photo's so it didn't happen!
Old Sep 9, 2012 | 08:46 PM
skeeters65's Avatar
skeeters65
I got plenty of photos but they are on my iPhone and a hassle to upload to here.
If you want something specific just let me know.
Old Sep 9, 2012 | 10:35 PM
striper's Avatar
striper
Good luck! I did mine by myself, in a 2 car garage. Not too bad with the right tools. Also had to do the diff/axle seal, it's very common.
Old Sep 9, 2012 | 11:21 PM
klattu's Avatar
klattu
Cruising
Default Seeing is...
In my future, hope not too soon.
Did you go back with a stock replacement clutch?
Something better?
How bad was it when you decided to tear into it?
Old Sep 10, 2012 | 12:00 AM
Dope's Avatar
Dope
Resident moron
2 car garage? That would be heaven. I did mine, and wrote the guide all in the middle of my driveway. Hell, it was my parent's driveway in fact (this was 10 years ago).
Dope
Old Sep 10, 2012 | 08:25 AM
skeeters65's Avatar
skeeters65
My stock clutch was shot. I couldn't go over 3000rpm in 4,5,6th gear or the pedal would stick to the floor. Friend that was helping me never rode in the car and thought I was joking how bad it was. When he pulled the clutch and flywheel from the motor he just laught at how bad it looked.
Any way I am putting in a McCloed RST along with their flywheel and new slave l, TO bearing, pilot bearing, and remote bleeder.
Old Sep 10, 2012 | 09:24 AM
Coach62's Avatar
Coach62
St. Jude Donor '12
How high up off the ground did you get it? Do you have headers to contend with?
Old Sep 10, 2012 | 10:08 PM
skeeters65's Avatar
skeeters65
It is up on jack stands. They are pretty tall though. I Daneasure it of you want.
Yes I do have headers. I unbolted them but don't think I needed to. Going to leave the bell housing on and just rotate the motor to get to the bolts.
Old Sep 10, 2012 | 10:43 PM
Coach62's Avatar
Coach62
St. Jude Donor '12
Thanks, but no need, I was just curious. I imagine it was pretty tight down there, laying on your back and all.
Old Sep 10, 2012 | 11:41 PM
striper's Avatar
striper
You didn't say which headers you have, but I have LG streets and you will find it easier if you unbolt them and move them. Trust me, you will find out they are just annoyingly in the way.
Old Sep 11, 2012 | 12:49 AM
skeeters65's Avatar
skeeters65
Actually it was the perfect height. Laying on a creeper is fine and it came out on the tranny jack just fine.
Old Sep 11, 2012 | 12:50 AM
skeeters65's Avatar
skeeters65
I have ARH headers. I did unbolt them.
To Started clutch install
