serpentine belt help please
Old Sep 10, 2012 | 10:38 PM
96 BAM's Avatar
96 BAM
Default serpentine belt help please
I need to replace the serpentine belt on my 2k C5. What is the best belt out there? Am tired of hearing birds chirp under the hood until the car gets to temp. Thought the Gatorback was the best choice (viewing an older thread) but am not sure now since I heard they have been discontinued by Auto Zone due to breaks. Your thoughts please.
Thanks in advance, Bob.
Old Sep 11, 2012 | 01:08 AM
mighty mousd's Avatar
mighty mousd
Gatorback
Old Sep 11, 2012 | 01:54 AM
Last C5's Avatar
Last C5
Originally Posted by mighty mousd
Gatorback
No noise and they last a long time.
Old Sep 11, 2012 | 06:44 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Gatorback
Plus they are cheaper than OEM.
Old Sep 11, 2012 | 09:36 AM
96 BAM's Avatar
96 BAM
Just ordered a Gatorback belt and am looking forward to some peace and quiet under the hood. Thanks to all for your input.
Bob
Old Sep 11, 2012 | 12:54 PM
my50thAE's Avatar
my50thAE
What are the part #'s for the Gatorbacks?
Old Sep 11, 2012 | 01:00 PM
Trios's Avatar
Trios
The part numbers are listed in this post I made a little while back when replacing my A/C compressor:
http://forums.corvetteforum.com/1581544782-post7.html
Old Sep 11, 2012 | 01:05 PM
NukeC5's Avatar
NukeC5
I love the gatorbacks. They are the only belts that stayed quiet for me.
Old Sep 11, 2012 | 02:10 PM
RealmSteel's Avatar
RealmSteel
I prefer Gatorback belts myself, but check the harmonic dampener pulley for wobble before putting the new belt on.
On my car, my chirping was caused by a bad tensioner.
Old Sep 11, 2012 | 06:07 PM
genokron's Avatar
genokron
2nd Gear
put in new compressor. ac will not hold charge and chirpping noise now. Do i need to replace the condensor?
Old Sep 11, 2012 | 06:18 PM
Trios's Avatar
Trios
Wow, that's a bit off-topic for this post.
We can't just say 'replace the condenser' and you'll be good to go; you have to determine where the leak is. Perhaps at the back of the compressor where the lines attach, perhaps at the condenser, perhaps anywhere...you need to find the leak. I recommend you start your own thread for this troubleshooting though.
Old Sep 11, 2012 | 08:09 PM
RealmSteel's Avatar
RealmSteel
In my experience, the chirping noise is caused by pulleys not aligned, wobbling balncer pulley, bad idler wheels or bad tensioner bushing.
Actually, if everything it not perfectly aligned and in good working order, you are going to have some sort of problem.
For the AC guy, did the system hold a charge before you changed out the compressor?
If so, check to make sure the o-rings are in place and not damaged at the connections you loosened or removed. The tensioner bushing for the AC is what was bad on my '01 when I had the chirping. I'll bet that is where your chirping is coming from.
You can check what belt is chirping by taking off the main belt and starting the car.
If it still chirps, the problem is with the AC belt.
You can let the car run for a minute or so, but I don't like letting it run longer because the main belt is what turns the water pump.
Old Sep 11, 2012 | 11:02 PM
96 BAM's Avatar
96 BAM
My harmonic balancer does wobble slightly. Maybe I have more issues. Will install the Gatorback and replace the tensioner as well. Thanks for your input.
Old Sep 12, 2012 | 07:30 PM
RealmSteel's Avatar
RealmSteel
Get the belts and figure out which one is chirping.
I didn't measure the run out on my old pulley, so it's hard to say what may be acceptable.
At this point, I say zero.
It's pretty expensive to swap out the harmonic damper mainly due to the labor involved.
Since I do all my own work and have the necessary tools, it's just time and aggravation for me. I'm sure if you do some searches around here, you can see what other may have paid.
For my problem, I figured the wobbling pulley was causing sideways stresses in the tensioner by moving the belt back and forth on the idler. Once the bushing wore, it couldn't do it's job properly. I swapped out the pulley prior to getting a new tensioner, but it's possible the chirping may have gone away with just the tensioner being replaced.
To serpentine belt help please
