HELP! Cooling problem
Old Sep 11, 2012 | 01:23 AM
Rwvette2's Avatar
Rwvette2
Default HELP! Cooling problem
I just started having some cooling issues yesterday, I was driving on the highway and the check gauges light came on. It said that the coolant was over temp. Turning off the A/C and turning the heater did not really do much. Got back on and drove right home with it. This morning I drove it to work no issues... drove it to lunch, let it ideal for a while never broke two hundred degrees(this is in TX with 98 degree weather today) sat there for 10 mins never had an issue. Then tonight I was driving home and on the highway it started to rise(I did get on it a little on the way out of the parking lot to test it out some) half way home the same lights came on saying coolant was over temp then right when I was pulling in it was showing 270 and reduced power as I was gliding into the garage. I had some coolant come out the top of the cap, nothing else. I have never flushed my coolant system and am thinking this could be an issue, but I am really thinking this could be the thermostat since the car is an 04 and I don't think this has ever been changed... Any thoughts on this? Where should I start to have a dealership look? I live in an apartment so I really dont have anyway to work on it so I am looking to do this as cheap as I can. Thanks for any advice
2004 stock Corvette(not a Z)
Old Sep 11, 2012 | 07:35 AM
runner140*'s Avatar
runner140*
Answered you in the "general" section.
