Transmission wiring need help!!!
Old Sep 11, 2012 | 08:23 AM
baezi z06's Avatar
baezi z06
Default Transmission wiring need help!!!
Hi
i need to check the PCM, plugs and all wires from PCM to Transmission (4l60e)
i´m getting pulse (rattle) to the 1-2 solenoid and the transmission is not working correctly, it doesn´t take the 1st gear or like it stuck between gears or in two gears at the same time.
and when i put it in D it starts in 4th
in 2nd it starts in 2nd and 3rd is just 3rd
but i can manual shift it from 2nd to 3rd and 3rd to 4th
the valvebody was take out and the solenoids work correctly on the table , so it is like the problem is in the harness or PCM
i rechecked all wiring i installed , got a RPM jumper harness and then Reflashed the PCM to tell it it´s AUTO
i don´t have a service manual , it´s not sold here in Iceland
i need to know what signal i´m looking for from each pin/wire
if you don´t know what i mean , i mean like what pin/wire sends ground signal , what signals V and what signals pulse.
do you guys have any chart what so ever you could send me camarof1@visir.is or maby know where i can find these informations on the web.
thanks
Baezi
Old Sep 11, 2012 | 09:31 AM
3boystoys's Avatar
3boystoys
You can order a manual from Helms of get one on Ebay.
Old Sep 11, 2012 | 09:36 AM
baezi z06's Avatar
baezi z06
I´m over seas, i´m in Iceland and need these infos fast
Baezi
To Transmission wiring need help!!!
