The HUD is powered from the IPC (Instrument Panel Cluster), no separate fuse, if your cluster is working correctly, then your problem is probably the HUD itself.
They use a vacuum florescent display that requires high voltage, the displays and power supplies (both internal to the HUD) do go bad, I have a couple dead ones laying around.
