Brentdes
Old Sep 14, 2012 | 10:34 AM
BrentDes's Avatar
BrentDes
Default Brentdes
Hi . I am new to the forum. Just bought a 2001 Vette coupe. I have 2 problems ( maybe they are related). Periodically my ABS and Traction control lighjts come on at the same time and stay on. When I turn off the ignition and restart the car the the lights go out. Sometimes I have to do this several times before the lights go out
2nd problem--seems strange to me. Hope I can describe it correctly. While driving, 40-50 MPH and take my foot off the accelerater, the car seems to instantly point slightly to the right. When I step on the accelerater the seems the go back to the left-It actually feels like the rear of the car moves laterally. I don't feel it in the steering wheel.Strange??......Please help
Last edited by BrentDes; Sep 14, 2012 at 11:11 AM. Reason: ABS and Traction Control Lights and veers to the right
Old Sep 14, 2012 | 11:19 AM
cdkcorvette7's Avatar
cdkcorvette7
Welcome to the forum
For assistance with your first problem pull and tell us your Diagnostic Trouble Codes (DTC's) from the car's DIC. I'll post the procedure for doing so below. It's very easy and something EVERY C5 owner should know how to do.
For your second problem you might consider having your alignment checked
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Sep 14, 2012 | 01:04 PM
maxx2200's Avatar
maxx2200
Welcome and you'll find a plethora of information on this forum as well as some of the most knowledgeable and helpfull Vette experts.
Old Oct 2, 2012 | 10:11 PM
BrentDes's Avatar
BrentDes
Thanks-found the problem. Left rear tie rod end was bad. Had it replaced (not cheap) and had a good 4 wheel alignment. Drives like a new car now.
Now for my other problem. The ABS and the Traction control lights come on very often together. I can erase them by shutting off and turning on the ignition-anywhere from 2 times to ten or more times. The codes are : BO-RFA U1000H and U1064H . 28-TCS C1214H. Hope you can help..... Best Regards ....Brent
Old Oct 3, 2012 | 12:10 AM
cdkcorvette7
C1214 is a bad internal relay in the EBCTM. You're lucky you have an 01. The 01+ modules can be repaired, the earlier ones cannot and there are zero new and very few used modules available. You can start by checking your ebctm ground but it's almost definitely the internal relay. These things have a very high failure rate.
If you're good soldering circuit boards (don't make this one your first attempt because it's expensive if you screw up) then you can fix it yourself. There's a very detailed DIY on this forum.
If you'd rather have someone else do it you can pull it out and send it to absfixer.com or one of many eBay vendors that will do this repair.*
Note that your car will be driveable with the module removed (you are effectively driving without it now) however you will not have abs or traction control so drive accordingly.*
Old Oct 3, 2012 | 08:12 PM
BrentDes's Avatar
BrentDes
Thanks, I will look into that
To Brentdes
