Noise after removing bolts
Old Sep 14, 2012 | 08:44 PM
CLEAR's Avatar
CLEAR
Default Noise after removing bolts
I lowered by removing front bolts. Looks great by the way, sitting at 26 inches. Now I can hear a grinding/scraping noise at low speeds mainly during left turn. Help.
Old Sep 14, 2012 | 08:51 PM
RealmSteel's Avatar
RealmSteel
I don't believe you are supposed to remove the bolts.
See this link.
http://frankhunt.com/FRANK/hobbies/c...5_Lowering.htm
Old Sep 15, 2012 | 10:42 AM
abflyboy's Avatar
abflyboy
you did?
pics or it didn't happen
When I lowered mine, the front air dam started dragging going through dips and backing into my driveway. Mainly the end parts but it sure makes a racket.
When the crash bar hits for the first time you will think you are going to die.
Old Sep 15, 2012 | 10:57 AM
NukeC5's Avatar
NukeC5
You are supposed to turn the bolts a bit, but not remove them....
Old Sep 15, 2012 | 12:00 PM
Supercharged111's Avatar
Supercharged111
Don't the bolts have a rounded tip to ride on the isolator that sits on the spring? Meaning irrepairable damage is now being done to said isolator?
Old Sep 15, 2012 | 12:23 PM
lionelhutz's Avatar
lionelhutz
The end of the spring is likely grinding into the control arm. You're going to need something in there to cushion it.
Old Sep 15, 2012 | 12:57 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Bad idea, re-install them or risk damaging the leaf spring
Old Sep 15, 2012 | 04:29 PM
CLEAR's Avatar
CLEAR
what about all the people on here who have removed bolts. its not uncommon
Old Sep 15, 2012 | 04:41 PM
NukeC5's Avatar
NukeC5
Ive never heard of that before... people lower on stock bolts, not remove them. Maybe you are mistaken somehow?
Old Sep 15, 2012 | 05:05 PM
Dope's Avatar
Dope
Resident moron
Lots of people remove them, but you'll want to put something between the spring and control arm so you're not getting metal on metal contact. Some people even use some cut-up pieces of inner tube for example.
Dope
Old Sep 15, 2012 | 06:27 PM
lionelhutz's Avatar
lionelhutz
Already answered,
try a piece of truck mudflap.
Old Sep 15, 2012 | 06:30 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Dope
I may be wrong, but isn't it metal on fiberglass?
Old Sep 15, 2012 | 07:54 PM
98DC231's Avatar
98DC231
I thought they replace them with diff bolts.
Old Sep 15, 2012 | 08:22 PM
bumble-z's Avatar
bumble-z
There is a metal (female insert) designed into the spring itself, that allows the adjuster to screw into the spring.
When the adjuster is remove there would be metal to metal contact.
Under those conditions it would be best for a rubber buffer to be laid between the metal spring insert & arm.
Also under those conditions the ride would be quite harsh & unforgiving.
Old Sep 15, 2012 | 10:04 PM
cptinjak's Avatar
cptinjak
I glued a piece of rubber onto the control arm. Two years later they are still holding up well. The shocks are blown and creaking, but the spring and control arm are doing great!
Don't listen to people that say "YOU WILL DEFINITELY BREAK EVERYTHING AND CRASH AND DIE."
Just get a nice durable cushion attached to the control arm (as mentioned, an inner tube would work well) and get a decent alignment.
Jack
Old Sep 15, 2012 | 10:06 PM
cptinjak's Avatar
cptinjak
Have you ever actually seen someone damage a spring this way? Not trying to be critical of your advice, but I have seen SO many cars with bolts removed that I figured if this were a problem I would have run across a damaged spring by now.
Jack
Old Sep 16, 2012 | 12:53 AM
Dope's Avatar
Dope
Resident moron
Possibly I was thinking the front spring has a metal bracket of sorts around the ends of it, like the rear spring. But I am probably mistaken now that I think of it.
Dope
To Noise after removing bolts
Old Sep 16, 2012 | 04:42 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Originally Posted by cptinjak
Have you ever actually seen someone damage a spring this way? Jack
Yes
Old Sep 16, 2012 | 08:01 AM
whisperinsam33's Avatar
whisperinsam33
That noise during left turns is your right front tire scraping the fender. Ask me how I know.
Old Sep 16, 2012 | 11:24 AM
lionelhutz's Avatar
lionelhutz
Jack
Well, even if you put something to protect the spring to A-arm on the front you're still lowering the back so far that it is riding on the bump stops. The cars lowered that way must really suck to drive on any road that isn't nice and smooth.
To each there own though. I drive my car far too many miles a year for it to ride like a harsh piece of crap.
