Noise after removing bolts
To each there own though. I drive my car far too many miles a year for it to ride like a harsh piece of crap.
I put about 20k a year on my car, and it is slammed. You don't NEED to sacrifice comfort for aesthetics, most people simply don't take the extra steps to ensure both.
Jack
Jack
Last I checked, no-one lowers the front 2" or more without lowering the rear. It must be nice to live where the roads are smooth. I'm not even fully lowered on stock bolts which gives almost 2" of suspension travel and I still get into the bump stops. I both raised it a little and cut the bump stops in 1/2 because I had a little over 1" of travel and it was into the bump stops all the time on rougher roads.
FYI, this is with the bumpstop cut in 1/2 with 305/30/19 tires
I took about 1/4" off the bumpstop which gives almost 1/2 more travel. As you can see, I'm not making **** up, I disconnected the spring and tested and measured.
Oh yeah, I did raise the front a little too from being fully lowered on cut stock bolts because of the same problem. It would bottom out too, not as bad as the back but it still did. I'm likely right around where you'd get fully lowered on uncut stock bolts but maybe a little higher.
So what's the big secret? You cut the front mount off the frame and weld it back on higher and then cut-up the adapter plate for the rear and extended it up too? That's the only way I could see having decent travel on a slammed car when I looked at it. Cutting bump stops or modifying bushings certainly wasn't enough for a slammed car.
Jack
For the rear, I flipped the mounting "hat" upside down, this lets the spring rest up inside the bracket on the frame, gaining approximately 1/2 inch of travel on the shock.
Honestly, even with no bolts, I have never had issues getting into the bumpstops up front.
If I hit a bump large enough to bottom the shocks out, it happens at approximately the same time as the tires get into the inner fenders. Don't get me wrong, the car DOES bottom out, but you have to hit quite a bump to make it happen. Normal driving on MI roads is rarely enough to get into the stops.
I have had different experiences with different cars though. Even among base suspension cars, there seems to be a variance in spring stiffness. I dont have any facts or measurements to support that, so perhaps I should just keep my mouth shut. Just found it worth mentioning that some springs seem "looser" than others and get into the stops more.
Jack
The fronts don't rub but it's pretty obvious when the car bottoms hard on a decent bump. Raising the front a little (about where the stock adjusters would go) was enough to pretty much stop it from bottoming though.
Jack
