Upgrading a C5 1998 , need some help
Old Sep 15, 2012 | 11:05 PM
cptinjak's Avatar
cptinjak
Take that K&N bs off. Throw a stock box back on, and do a search for "flip tie mod".
Clean your clutch fluid and do a search for "ranger method". Learning to launch/shift is the single biggest performance mod you can do for yourself. I went 12.84 BONE STOCK, with runflats still on the car. Don't bother buying parts until you are in that neighborhood.
Once your driving is up to par, the first mod I would recommend would be hptuners. Learn to tune your car FIRST, so that you can enjoy 100% of the benefits available from every part you buy.
Then do longtubes, ls6 manifold/throttle body, cam, heads. In that order. Gears are an option, but I personally really like the stock gearing for all the commuting I do.
Jack
Old Sep 16, 2012 | 10:36 AM
WKMCD's Avatar
WKMCD
What's the budget? Lots of ways to go but it's all about cubic bucks.
Old Dec 25, 2012 | 04:58 PM
ijy's Avatar
ijy
3rd Gear
Default is torco synthetic motor oil 5w30 is good for corvett c5 1998 5.7 engin
is torco synthetic motor oil 5w30 good for corvette c5 1998 5.7 engin
ijy's Avatar
ijy
3rd Gear
Old Dec 25, 2012 | 05:02 PM
3boystoys's Avatar
3boystoys
Nitrous is the best for the $$$.
Old Dec 25, 2012 | 05:58 PM
Rob Petyo's Avatar
Rob Petyo
Probably gears 1st and then N20
Old Dec 26, 2012 | 11:06 AM
kabluie's Avatar
kabluie
Well, I say take a lesson from MASH. You are only racing one guy in his one car. The cheapest way to beat the guy is to use a little strategy. Sabotage his car. Nothing serious - a little tire slick on his rear tires - that should do it. <grin>
By the way, I live in North Bend.
Old Dec 26, 2012 | 11:08 AM
kabluie's Avatar
kabluie
Have a friend put the tire slick on the car just before the run while you distract the guy by talking to him some distance away with his back turned to his car.
Yes, in this case I believe in cheating. You're not there to run second to a ricer.
Old Dec 26, 2012 | 11:56 AM
Mattie Num Nums's Avatar
Mattie Num Nums
Learn how to drive or get Nitrous and pray.
Old Dec 26, 2012 | 12:49 PM
kabluie's Avatar
kabluie
One last thing. Don't brag about it.
Mattie Num Nums
Riding off into the sunset is always the best!
Old Dec 26, 2012 | 01:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Better tires and learn to LAUNCH properly. Learn how and when to shift. Your stock engine Tq drops off well before red line.
Here are the GET WELL/GO FAST things that I would do first.
- 2001+ Stock LS intake. 10 easy HP
- VARARAM Cold Air Intake 10-15 HP
- Stainless Steel Long Tube Headers Contact SUPERMAN09 for a set of XS Power headers (complete set with cats and midpipe = $900)
- Better tires
- 390 Gears (Contact forum member Rick Kim:
http://forums.corvetteforum.com/c5-p...ferential.html
After you Modify all that your budget will stand,, GET A PROFESSIONAL PCM TUNE!!!!!
You will be in the 380-390 RWHP 370 Tq range. Been there ,,, done that!
Once you get tired of that Hp increase, your next step up will be heads /cam /FAST 90, new clutch and wider tires. My o2 ZO6 is currently in the 450 RWHP range. All said and done, wish I would have just added a big ole supercharger!!!:ro fl:
BC
