Ready To Pull The Trigger
Old Sep 16, 2012 | 12:30 AM
FRITZM's Avatar
FRITZM
Default Ready To Pull The Trigger
Looking for a cam recommendation Y2K. CAI, Catted LTs, LS6 intake, LS7 lifters/trays, PRC 243 heads, Patriot dual springs, Ported LS6 TB, Ported LS6 oil pump, LS2 chain. I have been looking at TSP Torquer V2 112LSA. Anyone recommend something different or should I pull for this cam?
Old Sep 16, 2012 | 01:12 AM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Have you looked at anything from Englandgreen, I love my set up, drives great and makes really good power.
Old Sep 16, 2012 | 01:36 AM
FRITZM's Avatar
FRITZM
Default Cam
No I have not yet. The cam I'm looking at, Torquer V2 232/234 .595"/598 LSA 112, is supposed to work well with the set up I have. Reasonable hp/torque numbers and a nice lope. That's not to say I won't look elsewhere if another cam is more suitable, like EnglandGreen as you say.
Old Sep 16, 2012 | 02:24 PM
cptinjak's Avatar
cptinjak
What kind of use will the car see? how important is drivability, power under the curve, idle quality, etc etc. Can't really make a suggestion without knowing that.
Jack
Old Sep 16, 2012 | 04:06 PM
FRITZM's Avatar
FRITZM
Default Cam
I have a 2010 Camaro SS w/CAI/headers and Magnaflow catback as a more or less DD. I want the vette to have reasonable power/torque throughout the curve. It will be mostly a weekend/summer vert. Drivability is important as I will probably drive it to vacation destinations for its economy vs the Camaro. Just want a beefy street friendly car with a nice lope. No tracking (OK maybe once in a while just to stretch its legs). Thanx for the reply and more questions, if you have some, are welcome.
BTW the Torquer V2 was recommended by (guess who) TSP after I told them my mods.
Old Sep 16, 2012 | 04:15 PM
cptinjak's Avatar
cptinjak
The v2 is a 232/234 unless I am mistaken. You will make good power and the 114 LSA will keep the idle quality in check with a decent tune. I think the v2 is a great choice for what your needs are. With a good tune your drivability will remain mostly intact, while going much bigger would start to hurt.
Jack
Old Sep 16, 2012 | 04:26 PM
cptinjak's Avatar
cptinjak
Forgot to mention, if this car is an auto, you may need a stall to compensate for this cam.
Jack
Old Sep 16, 2012 | 06:09 PM
FRITZM's Avatar
FRITZM
Default Cam
Thanx cptinjak. You are right 232/234 595/598 but I was thinking 112 LSA. Too much?
Old Sep 17, 2012 | 01:17 PM
cptinjak's Avatar
cptinjak
For your goals with the car, I would stick with the 114. It will still be a noticable lope in the idle if you want, but the drivability at low rpm will be much better than the 112.
Jack
Old Sep 17, 2012 | 02:04 PM
FRITZM's Avatar
FRITZM
Default Cam
Ordered the 113 LSA. Split the difference.
To Ready To Pull The Trigger
